09-03-2008
Originally Posted by SailingFlorida
any method that works best in cleaning with it? Wondering if soaking them in a large barrel and oxiclean would remove some of the dingyness? or should i work on section at a time? sponge or srubing brush? thanks
A scrubbing brush will work best - you really do not want to soak per se, just enough to scrub and rinse and get them clean. Soaking is bad IMHO - as you can never really get the suds back out and even Oxyclean likes to attract dirt as it is more like a base... so you really just want to get the job done and rinse and rinse some more.. as if detergent is left on the sail it will deteriorate..
-- Jody
S/V " To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. " - 1983, Barberis Show 38! or To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
