Old 09-04-2008
sailcata30 is on a distinguished road
Rudder post hole
Hello,
I have a 1975 Catalina 30. It has a leak at the top of rudder post hole and under the wheel gear for the steering.
It only leaks while underway and not at the dock.
Anyone out there have info on this issue?
Thanks in advance
sailcata30
Old 09-04-2008
funsailthekeys is on a distinguished road
Is there a packing assembly on the post? If so it may need to be tightened down just like a prop shaft would.
Old 09-04-2008
That seems resonable but as for as i can tell there is no packing (like shaft packing). There are 2 rings that are loose and right above that a hose clamp around the rudder post. The water is coming from the top of the rudder tube where the rudder post slides in. ?
Building a New Ruuder Armchairprotest Gear & Maintenance 16 12-06-2009 10:15 PM
8.0B rudder post dorourke S2 5 12-09-2008 12:40 PM
What Makes a Good Opening Post sailingdog Off Topic 40 05-27-2008 09:38 PM
Bent Rudder Post - C&C 36 PSSEATTLE Gear & Maintenance 4 05-18-2001 08:42 PM
Rudder Post Packing Gland kapt_ken Gear & Maintenance 1 03-25-2001 02:47 PM
