09-05-2008
A better page would be Halekai's article on actually replacing seacocks and through-hulls. Sealant, like 3M 4200, should be used on the flanged base and on the throughhull itself—as seen in his photos.
The plumber's putty might be good on a pipe...but not so good for use on a through-hull IMHO. If the seal between the through-hull itself starts to leak, rather than the threaded connection, the plumbers putty will do nothing to stop it from entering the boat. Putting a good bead of sealant under the base of the flange, in addition to plumbers putty on the threads, will stop the water—whether it is coming down from the threaded bit or up from the a leaking through-hull bedding job... a much better idea IMHO.
