09-06-2008
Without knowing exactly what kind of plastic it is, it is hard to say whether it can be successfully repaired.
As for converting a water tank to diesel use...without knowing what the water tank is made of you'd be making a big mistake. If the tank is regular polyethylene, rather than cross-linked polyethylene, it will be likely to be damage by the fuel and leak. Also, many water tanks on a boat with multiple tanks are cross-plumbed, so water can be transfered from one to another. If that is the case here, you'd have to disconnect and plug those fittings as well. Finally, a diesel fuel tank needs a return line, and most water tanks don't have a fitting for it.
