Low Power in Fwd - Page 2 - SailNet Community
post #11 of 17 Old 09-06-2008
Omatako's Avatar
Originally Posted by Stillraining View Post
That wouldn't cause the high torque, bog down creating the black smoke and over fueling ( Raw diesel in Exhaust ) though...
It sometimes pays to read the whole thread . . . .
Andre
Omatako is offline
post #12 of 17 Old 09-07-2008
Or at least the whole first post....
Andre
sailingdog is offline
post #13 of 17 Old 09-07-2008
davidpm's Avatar
wouldn't be surprised if the prop is fouled.
Why would a fouled prop cause black smoke?
davidpm is offline
post #14 of 17 Old 09-07-2008
svitineris's Avatar
Check the Prop
svitineris is offline
post #15 of 17 Old 09-07-2008
ancient mariner
captbillc's Avatar
with a fouled prop, the engine gets bogged down with the throttle wide
open because of the heavy drag of the fouled prop the engine RPM can not come up. the overloaded engine will put out black smoke-- it is like when you see an 18 wheeler going up a hill & the driver doesn't shift down soon enough the same think will happen with a prop that has too much pitch, the engine can never get up to rated RPM
captbillc is offline
post #16 of 17 Old 09-08-2008
davidpm's Avatar
[quote=captbillc;364806] the engine can never get up to rated RPM[/quote
Thanks
davidpm is offline
post #17 of 17 Old 09-08-2008
The amount of fuel being injected is too much for the rpms the engine is turning and therefore there is not enough air to properly burn the fuel.
SteveInMD is offline
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 07:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 07:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 07:00 PM
