Trying to get an older Universal diesel running...experience appreciated! - Page 3 - SailNet Community
post #21 of 23 Old 09-11-2008
Handsome devil
Stillraining's Avatar
Interesting engines Iv never seen one before...Looks to be hot exhaust.
Stillraining is offline
post #22 of 23 Old 09-13-2008
My olde diesel tank does not have a fuel return line. The motor is a 1977 Volvo MD17C.
Clean fuel and oil and that old motor will probably start and run fine. It probably just needs some exercise.
Rockter is offline
post #23 of 23 Old 09-13-2008
Rockter-
AFAIK, If the return line doesn't go into your tank, it still has to go someplace. It can be plumbed back into the feed line (bad idea, the fuel can't cool down and warm fuel doesn't burn with as much power) or it can be plumbed into the fill line, but it has to go SOMEwhere. Or else the high pressure pump and injectors are getting a needless workout against the excess pressure.
Sending it back into the tank allows it to mix with the cooler fuel in the tank and cool back down.
hellosailor is offline
Universal diesel engine problem bcolton Gear & Maintenance 6 06-11-2012 02:07 PM
philosopher's club, anyone? HoffaLives General Discussion (sailing related) 91 03-26-2009 12:44 PM
My learn to sail experience! merlin2375 Learning to Sail 13 05-30-2008 10:08 PM
White Smoke from Older Diesel at Higher RPMs kcoffey Gear & Maintenance 3 06-24-2004 03:23 PM
Refitting an Older Boat Sue & Larry Gear and Maintenance Articles 0 12-16-2000 07:00 PM
