Old 09-09-2008
all these confusing ropes
dohenyboy is on a distinguished road
don't want to highjack the Autoprop thread
but I have an Autoprop and I have a problem with it.
When I start out, I have my engine at idle and then put the transmission in forward. As I advance the throttle, the engine speed does not increase. I will eventually climb up to about 2 knots in speed, nothing more.
If I put the lever in neutral, the engine rpms increase normally.
If I have the rpms at about 1500 and slam into forward, the engine keeps the rpm and I can accelerate to displacement speed. which is okay but I think its hard on my gearbox.
Any ideas on what is happening?
thank you
Old 09-09-2008
artbyjody's Avatar
artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice artbyjody is just really nice
Send a message via AIM to artbyjody Send a message via Yahoo to artbyjody
Try giving it more "gas" after you have placed the control into forward or reverse for about 20 seconds or so. It will cause some cavitation but when you reduce the "gas" you'll be able to throttle and control the the speed appropriately.. depending on the pitch of your prop - will determine how much you need or how long you need to cavitate.. If it is still an issue then you will want to look at changing the prop pitch at some point (which I had to do with my feathering prop)...
Good luck
-- Jody
S/V "
1983, Barberis Show 38! or
Old 09-09-2008
It actually sounds like your autoprop needs some maintenance. It isn't opening properly...sticking shut, so you don't get the speed out of it, unless you kick it open by switching from neutral to forward at 1500 rpm.
Old 09-09-2008
christyleigh's Avatar
christyleigh is on a distinguished road
I think SD's first sentence covers it but I'll add a bit from having installed an AutoProp on my last boat for 5 years and another 3 years with the AutoProp that came on my current boat. AutoProps don't open and close. They are Featherers not Folders. The name "AutoProp" comes from the fact that they Auto Pitch themselves driven by the Need or Not by things like being helped by sails etc... If in fact your AutoProp was wrongly pitched to your hull/motor config you would have to send it to the factory for adjustment. If as you say when you properly - and Don't do it any other way - shift at an idle it won't spin up it sounds like in that particular case the blades were so stuck out of alignment that your engine couldn't handle it. They may need lubrication which is recommended at least every other year. While my boat is still tied to the dock I always kick it into reverse, rev it a bit, and then to forward to make sure it's doing what is should. If I don't move the whole floating dock system at least a few inches in each gear I know I have a problem - but that has never happened in 8 years with AutoProps. Great for Motor-Sailing because it self adjusts/pitches to the needs of the engine
Stan
'Christy Leigh'
NC 331
Wickford/Narragansett Bay RI
Old 09-09-2008
jrd22's Avatar
Courtney the Dancer
If I understand the OP correctly, the engine doesn't increase RPM at all when in gear. Sounds like something is fouled on the prop to me. You should be able to reach governed RPM with the Autoprop even when tied to the dock. Even if all the blades were stuck in the maximum pitch position (hard to imagine how this would happen) you should still be able to increase RPM, but the engine would probably be making black smoke and wouldn't reach full speed. I would have a diver check what's going on down there.
John
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
Old 09-09-2008
Originally Posted by jrd22 View Post
If I understand the OP correctly, the engine doesn't increase RPM at all when in gear. Sounds like something is fouled on the prop to me. You should be able to reach governed RPM with the Autoprop even when tied to the dock. Even if all the blades were stuck in the maximum pitch position (hard to imagine how this would happen) you should still be able to increase RPM, but the engine would probably be making black smoke and wouldn't reach full speed. I would have a diver check what's going on down there.John
That was my first thought also but the OP said once he got it (jammed it) into gear he reached hull speed which is why my best Guess would be sticking.
By the way one other thing I didn't mention in my earlier post is that the AutoProp completely Reverses the Blades in Reverse. That is why they back up just as strong as they go forward - But that also means if they get stuck in the middle the thing has absolutely No Resemblance to a Prop and would offer Extreme Resistance to turning not just the "maximum pitch position" John mentions. But agreed..... the poor engine should be belching smoke and the prop shaft should be dancing a jig and sounding like it wants to free itself from the boat if it was stuck with the blades all facing different directions
Stan
'Christy Leigh'
NC 331
Old 09-09-2008
thank all, yes prop is clean, diver says all looks well. I have to haul it out to get the antifouling renewed so will plan on lubing it. don't think that has been done since I have had it (three years)
Old 09-09-2008
dohenyboy-
it may need to be shimmed or such, since lubrication isn't the only thing that can cause a folding/feathering prop to stick.
Old 09-09-2008
RXBOT is on a distinguished road
Prop
Isn't the Autoprop feathering not folding? But I assume it could get stuck in any position, such as stuck in reverse configuration when UR trying to go forward or stuck in feathered and you can't go anywhere. If the prop is not acting normally I can see severe potential problems. Poster should get it pulled and serviced by competent facility.
Old 09-09-2008
jrd22's Avatar
Courtney the Dancer
Rxbot- you're correct, it is a feathering prop, or variable pitch. Each blade is completely independant of the others. They rotate on individual bearings and just flop around when you turn the shaft slowly. They are built so that the centrifugal force throws them out in the correct direction, forward or reverse, and the higher the RPM the finer the pitch until the boat speed increases the water flow over the blades so they increase the pitch. You really need to use a lot of throttle initially to get going or stop (but you can stop on a dime if you need to). In a rough sea where forward speed is constantly changing the blades change with the speed, continuously and automatically, without changing the engine RPM.
I don't think that this could be a prop issue if it is clean and the blades move freely (I would guess the diver would have checked this?), but I'm stumped about what might be causing it. Could there be fish line or something in the cutlass bearing creating a severe drag?
PS, I love the idea of the Autoprop and it works great, just not sure I'm going to put one on the new boat in light of the reports of the newer ones losing blades.
John
SV Laurie Anne
NEWCOMERS-To Get More Out of Sailnet sailingdog SailNet FAQ's 152 03-07-2012 11:04 PM
I Care to Much and Desire Goodwill thread artbyjody Off Topic 22 05-27-2008 12:34 PM
Autoprop - Exceptional customer service jreidvt Gear & Maintenance 1 06-13-2006 03:59 PM
canvas thread? e31 Gear & Maintenance 5 12-26-2003 03:54 PM
First Look: AVP Autoprop Mark Matthews Gear and Maintenance Articles 0 04-19-2000 08:00 PM
