Can you turn a spinnaker into an asymetric & $$ - SailNet Community
post #1 of 6 Old 09-09-2008 Thread Starter
brianontheroad's Avatar
I've got an old spinnaker, but I don't think I'm going to be using it much -- my partner is fairly inexperienced and I don't think she's going to be up to the task. We're going cruising in Feb, Carribean -- I was thinking about taking my spinnaker to a sailmaker and have it turned into an asymmetric. Is that a major over haul? Or is something a good sailmaker should be able to do fairly easily -- my budget would be anywhere from 400 to < 1000 or is that wishful thinking.
Thanks!
Brian
brianontheroad is offline
post #2 of 6 Old 09-09-2008
On the hard
CharlieCobra's Avatar
No, totally different cut and structure.
CharlieCobra is offline
post #3 of 6 Old 09-09-2008
trantor12020's Avatar
Since you're cruising and not racing, you can still fly a symm like an asym, use an ATN Tacker to hold the tack to forestay/roller-furler.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
trantor12020 is offline
post #4 of 6 Old 09-09-2008
A standard Symmetrical spinnaker would not really be effective as a "cruising chute", as Charlie says.
If you're Island hopping in the Eastern Caribbean, the general sails set are a reefed main and small/partial headsail... don't really see the need for a spinnaker of any sort for the most part.
It likely wouldn't be worth your (or the sailmakers') while to try to convert an old spinnaker.
Faster is offline
post #5 of 6 Old 09-10-2008
mikehoyt's Avatar
If you are not planning to use the spinnaker you should look for a used Asymmetrical spinnaker and look into selling your current spinnaker and pole. A sysmetrical spinnaker plus spinnaker pole is a costly addition to a boat and there are lots of people on lookout for a used one. By contrast the asym requires no pole and is far less costly to obtain.
If you sell what you have and buy an asym you should come out ahead.
Mike
mikehoyt is offline
post #6 of 6 Old 09-10-2008
spinnaker
look on ebay I see quite few for auction, I actually bought one from ebay 400 with sock good shape. check it out for a week or so .
sonofasonofasailer456 is offline
Spinnaker Takedown Basics Dean Brenner Racing Articles 0 04-28-2002 08:00 PM
Spinnaker Fundamentals Steve Colgate Learning to Sail Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Seamanship Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Gear and Maintenance Articles 0 06-24-2000 08:00 PM
Spinnaker Fundamentals Steve Colgate Racing Articles 0 06-24-2000 08:00 PM
