Old 09-10-2008
pwinkler is on a distinguished road
Serious corrosion mystery
Last month we took our Ranger 33 out for a day sail from Swan Creek on the Chesapeake. We could hardly make any headway. We had the boat pulled for a cleaning and sure enough, the prop was covered with barnacles and growth. The same thing happened to dozens of others this year, we discovered.
However, the shaft ( 1inch bronze) had what appeared to be severe stray current corrosion. It was even pinkish in large areas and had deep pock marks of 2-3 mm. The zinc wasn't touched at all, nor was the prop (Indigo), struct or any other fittings on the bottom. Just the shaft.
The service manager (Doug at Gratitude Marina) suggested it may have been caused by lightening. I used a meter to test all my bonding and everything was correctly bonded. This is an Atomic 4 engine, too. The AC circuitry was checked out and found to be proper as well.
Anyone seen anything like this before? Oh, the hull had large white patches where the bottom paint had come off, too. The bottom and shaft were fine when it was splashed at the end of April.
Very weird.
TIA,
Phil
Old 09-10-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Don't assume the corrosion you noticed was caused by stray current. There are many causes of metal corrosion in boats. We don't get much lightening out here so I can't speak to the likelihood of that but I have seen any number of boats with issues like yours. Bronze that is "pinked" has been de-zincified, that is, the zinc component of the bronze is depleted, leaving a weaker, brittle material, and may be the cause of the pitting you saw (although "pitting corrosion" is also a possibility.) You make no mention of the condition of the zincs. Were there any left?
Seems like the shaft was significantly compromised. Did you replace it?
"Clean bottoms are FastBottoms"
Old 09-10-2008
Sapperwhite's Avatar
Not So Senior Member
Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about Sapperwhite has a spectacular aura about
What is the salinity in Swan Creek, zincs don't work in fresh water. I know it's not fresh, but if its brakish or mostly fresh you may have trouble.
Dictated, but not read.
Old 09-10-2008
EO32's Avatar
EO32 is on a distinguished road
Why would zincs not work in fresh water?
I realize salt water is more conductive, but that doesn't mean fresh water is not conductive.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 09-10-2008
tommays's Avatar
"Aluminum anodes “self-clean” in freshwater. Zinc anodes can form a coating that stops them working ..."
There is also a lot of problems with buying brand X anodes becasuse of poup quality control of the alloy
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
Old 09-10-2008
Fstbttms's Avatar
My understanding is that zinc anodes do not have the electrical potential to overcome the higher resistance found in freshwater. That is why you should use magnesium or aluminum anodes in a fresh water or brackish environment.
Old 09-10-2008
As pointed out, you really shouldn't be using ZINC zincs in fresh or brackish water. Magnesium is best for fresh water, aluminum can be used in brackish...but it really depends on the salinity.
Old 09-10-2008
SteveInMD is on a distinguished road
The salinity of the Chesapeake Bay changes quite a lot over the course of the year. The heavier salt water forms a wedge shape under the fresh water that moves up the bay during the dry summer months and retreats in wet weather. The change in salinity can be fairly dramatic. This year was fairly wet and the salt wedge didn't come very far north so the water was fairly fresh.
Having said that I don't know if I should be using zinc or aluminum in the Annapolis area. I think most people use zinc. What would happen if I used one of each?
Old 09-10-2008
If there is any doubt, go with aluminum, and check them a bit more often. They're not that expensive and beat having to fix something due to galvanic corrosion damage.
Problem Seacock -dripping. Is this abig deal? Pamlicotraveler Gear & Maintenance 32 07-02-2008 12:14 AM
Jib hanks and corrosion kjsailingSpring Gear & Maintenance 5 08-06-2007 11:26 PM
Stainless 101 sailnaway Gear & Maintenance 2 01-28-2005 05:02 AM
Understanding Galvanic Corrosion Kevin Hughes Gear and Maintenance Articles 0 03-08-2004 07:00 PM
Spar Corrosion Demystified Mark Matthews Gear and Maintenance Articles 0 07-01-2002 08:00 PM
