Marinco Power Cables - Page 10 - SailNet Community
Blogs
  #91 (permalink)
Old 09-16-2008
GaryHLucas is on a distinguished road
If there are a large number of failures, then I'd autopsy one of the ones that failed. It should be easy to cut the connector apart and see how the connection to the wire is made, terminal screw, crimped, or soldered. You probably also can tell where the failure started, because that is likely to have been the hottest part. Charring as opposed to just melting and dis-coloring.
Charging with Solar Power Kevin Jeffrey Gear and Maintenance Articles 0 07-28-2003 09:00 PM
Electrical Power on Board Kevin Jeffrey Gear and Maintenance Articles 0 02-11-2003 08:00 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 08:00 PM
Boat Battery Power East Penn Manufr. Gear and Maintenance Articles 0 01-18-1999 08:00 PM
SEO by vBSEO 3.6.0
(c) Sailnet 2000-2006
