Old 09-10-2008
jarcher's Avatar
jarcher is on a distinguished road
Cleaning a fresh water tank - how?
Hi All...
I now have my first boat that's not a dinghy and find that there is just tons and tons of stuff I don't know. Well I expected that, but here is a really simple thing that never occurred to me.
Today, I tried out the foot pump int he galley and it spit out brownish purple "water." I was able to locate the fresh water tank and it seems to be in for good.
So, how do I clean it?
Thanks...
Old 09-10-2008
mman30 is on a distinguished road
Tank
The previous owner may have winterized the tank and used some kind of diluted anti-freeze, or the brownish stuff is just debris and god only knows what. I would try using regular house hold bleach mixture with water. let sit in the tank, and then flush it out with fresh water several times. If all you have is a foot pump (no mechanical pressure pump) you may want to see if you can access the top of the tank through a cap and wash clean the inside, and flush the water fill hose, and pump, and water lines. Thats my two cents.
Old 09-10-2008
Tank
And just as a precaution, I would check and make sure you did not access the holding tank. Brownish purple stuff that smells, You never know. LOL
Old 09-10-2008
jarcher's Avatar
Thanks for the tip!
I'm sure this is the fresh water tank. Its under the cockpit astern, while the holding tank is under the vbirth next to the head! And of course I have a bunch of head related questions, but I'll save that for another thread.
I suppose running a bleach solution through it would kill stuff, but would it get the fill line and the top of the tank?
Old 09-10-2008
Bacteria/mold etc in the water tank can cause that... a heavy dose of bleach, and flushing the tank several times will help clear it. You should probably also follow up the bleach shock treatment with several tanks of fresh water and then one of water/vinegar and then several more of water.
Let the vinegar/water mixture sit, since it will help neutralize any odors in the system.
I would also recommend, if you have an access hatch, to scrub the water tank's innards and replace all of the hoses.
The bleach will kill most of the stuff in the deck fill hose and the top of the tank, if you fill it so that water is pouring out of the vent.
Old 09-10-2008
SteveInMD is on a distinguished road
I would rinse out a few times before adding the bleach. This is for a system with a pressure pump, but I'm sure you can adapt the procedure. It takes a lot of rinsing so you want want portable electric pump for this. You can get a 110 volt version at the hardware store for not too much money.
Turn water heater off at the breaker before beginning. Do not turn it
on again until entire recommissioning is complete.
1. Prepare a chlorine solution using one gallon of water and 1/2 cup
Clorox or Purex household bleach (5% sodium Hypochlorine solution ).
With tank empty, pour chlorine solution into tank. Use one gallon of
solution for each 5 gallons of tank capacity, which results in 4
Ounces of bleach for 10 gallons of water.
2. Complete filling of tank with fresh water. Turn on every faucet and
allow water to run until what's coming out smells strongly of bleach.
3. Turn off faucets--but do NOT turn off the pump...it must remain on
to keep the system pressurized so that the solution remains in the
lines. Allow to stand for at least 3 hours, but no longer than 24
hours.
4. Drain the tank through every faucet.
5. Refill tank with clean fresh water and drain again through every faucet.
6. To remove excess chlorine taste or odor which might remain, prepare
a solution of one quart white vinegar to five gallons water and allow
this solution to agitate in tank for several days by vehicle motion
(iow, go sailing and tack a lot).
7. Drain tank again through every faucet, and refill with potable water.
Old 09-10-2008
jarcher's Avatar
Thanks guys. If I can get into the tank I'll scrub it and if I can get to the hoses I'll replace them. Better safe than sick. I think I can get to all the hoses from the tank to the pump and faucet, but the fill hose may be tricky.
I did notice that the local ships store had a variety of hoses in stock, so at least I can find them.
If I can;t get to the tank, lots of bleach and viniger...
Thanks very much!
Old 09-10-2008
Lancer28's Avatar
I'm the FNG still...
Lancer28 is on a distinguished road
Hey - don't forget to change or installl an dunder-sink water filter from your local home depot. I think they only run $20 and HOLY COW what a difference they make!
I've tried the bleach (which works great) on my own boats, and I've tried the vinegar to follow up. The vinegar was FOUL even after flushing, and I had to replace some hoses. I even tried a baking soda / water solution which dissolved good but still didn't kill it all off.
Make sure you pump the bleach up to the pumps and unti it comes out of the faucets or else it will all be just sitting in the tank.
Do you have hot water or a recirculating system, or is it old-fashioned pump from seawater and freshwater tanks?
Robert
I reject your reality and substitute my own.
Old 09-10-2008
jarcher's Avatar
That's a great idea, thanks!
Nothing that elaborate. I don't think there is a water heater at all. Just a tank with a fill hose running to the deck, and another hose running to a foot pump and from there to a faucet. Or maybe its better described as a nozzle.
The sink appears to drain to a fitting in the hull.
Old 09-10-2008
T37Chef's Avatar
Senior Culinary Member
T37Chef will become famous soon enough
Our marina has a drive thu water tank cleaner, very simple to use, somewhat costly but works well. After the cleaning 10 illegals come over and wipe it down...awesome I tell you
Shawn
S/V Windgeist
Tartan 37C #358
Photo by Joe McCary
THE Yacht Builders List:
Useful Food Purchasing Links:
Yanmar 2QM15 raw water pump problem menado Gear & Maintenance 3 07-23-2008 02:20 PM
the water in your tanks pegasus1457 Cruising & Liveaboard Forum 44 06-25-2008 05:49 PM
2GM20F - Fresh Water Circulating pump Bill R Island Packet 5 09-17-2007 12:53 PM
Fresh Water System Cleaning and Maintenance kcoffey Gear & Maintenance 2 07-13-2004 12:36 PM
