Old 09-11-2008
Maine Sail's Avatar
Engine Overheating Baseline Assessment
Hi All,
In the past few months there have been a rash of "engine overheat" topics here, and elsewhere, and I finally had a chance to photograph how I get a temperature baseline of my engine for potential future over heating events.
"Why the heck would I want to trouble shoot something before it's broken?"
The reason for doing this is because without knowing how your engine operates, and what the actual temps are of various points in your cooling system, it's nearly impossible to aim a thermometer at say the the heat exchanger outlet port and guess that it's out of range or blocked.
I've posted another article to my web site that outlines how to do a temperature baseline assessment.
Doing this is easy and it will save you time and money when you do have an overheat situation. With boats it's not a matter of if but when. I do need to take a couple of more pics but needed my tripod in order to do so. I'll add them to the article after I take them.
Engine Temp Monitoring & Over Heating Baseline Assessment
P.S. You won't read about this trick in the books..
______
-Maine Sail / CS-36T
Old 09-11-2008
Melrna's Avatar
Crazy Woman Boat Driver
Melrna will become famous soon enough
Send a message via AIM to Melrna Send a message via Yahoo to Melrna
When I bought my boat during the survey the overheat alarm went off at high RPM. My surveyor took out the temperature instrument you show in the photograph and instantly found the cause. It was the in the mixing manifold. It was a quick fix, Yammar had a recall on the mixing manifold as being to small. Yammar sent out a replacement in two days and I was back in business.
Another good use for it is to troubleshoot air conditioners. Taking the reading of input vs output air. There should be 20 degree difference.
I can think of a few other uses for it but I will reserve those for "Off Topic" section.
Melissa Renee
Rhapsody in Blue
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 08:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 07:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 07:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 08:00 PM
