Diesel from Gas Station - Page 2 - SailNet Community
post #11 of 16 Old 09-12-2008
Senior Mumble
jbondy's Avatar
Additives
Pokey's PO recommended adding 1/2 cup of Marvel Mystery Oil to each tank (22 gals) when refueling. I did that for a while, then stopped. Shortly thereafter, I lost pressure (actually, the engine did, not me) and I had to repower. Causal or coincidental? Makes me wonder, upon reflection.
jbondy is offline
post #12 of 16 Old 09-12-2008 Thread Starter
Irrationally Exuberant
Well, OK then. Sounds good. I'll put some lubricant in there when I finish topping up this weekend. So are there special lubricants for this job, or would the Marvel Mystery do it, do you think? Shoot, I've got some MMO, so that'd be easy.
BTW, I scored a pretty neat 5-gal diesel container at Kmart that has a push-to-flow no-spill filler that worked real well--got one drop on the coaming around the fill and that was it.
Tom K
2000 Beneteau 331
Northern Chesapeake Bay
arf145 is offline
post #13 of 16 Old 09-12-2008
ancient mariner
captbillc's Avatar
i worked for cummins diesel for 30 1/2 years. low sulfer fuel was always recomended. sulpher in the fuel gets past the rings during combustion and forms sulpheric acid which attacks the bearing material. i use nothing but automotive fuel in my yanmar 2GM20F .
captbillc is offline
post #14 of 16 Old 09-12-2008
Handsome devil
Stillraining's Avatar
Most of my equipments fuel gauges don't work after a few years of getting pounded and Jared around...I never bother replacing them..I lubricate my fuel too..every day or two I spit in the tanks to check fuel levels...
Stillraining is offline
post #15 of 16 Old 09-13-2008
I too use gas station fuel in my Yanmar. No problem.
SYMandalay is offline
post #16 of 16 Old 09-14-2008 Thread Starter
Good to hear from CaptBill and SYMandalay that they're using landlubber diesel in their Yanmars. I'm going that route for now. Thanks all for the info and feedback.
Tom K
2000 Beneteau 331
arf145 is offline
Filtakleen Ten 35 fuel additive??? Gas & Diesel T37Chef Gear & Maintenance 15 06-23-2014 12:32 AM
fuel consumption gas vs diesel jklewissf Gear & Maintenance 25 05-11-2013 07:28 PM
Diesel & Gas Engines? oceanmaui Gear & Maintenance 5 10-24-2004 07:40 PM
gas vs diesel reid5009 Living Aboard 1 02-07-2003 12:43 PM
Gas versus Diesel Tom Wood Gear and Maintenance Articles 0 01-10-2002 07:00 PM
