09-12-2008
Originally Posted by zz4gta
I tried it last night with this line
http://www.defender.com/product.jsp?path=-1|118|311417|314170|749707&id=829503&cartId=1006457
One of the worst experiences of my life. I just don't think the cover has enough give to allow it. The correct size fid didn't even push through. Tried using a hanger, then just a string tied to the end of the core which worked up until the end when I couldn't get the core back out of the cover. Hours, upon hours, upon hours. I'm tying a friggin knot. I may try again on my mainsheet to make it look a little better, but I'm thinking 1/4" is a bit too small for this type of splice. Maybe the line I'm using sucks.
The link is bad. What line is it?
I've used snares for over 15 years. Get a thin piece of tubing, cut the end at a taper, smooth and polish it, double a piece of line and run it through the tube with the loop end out of the tapered end. You can then use it like a Splicing Wand but much, much less expensive.
If you'll give some specifics about the line, I may be able to help.
Cheers,
MikeR
