engine smoke/vapor - SailNet Community
post #1 of 4 Old 08-03-2002 Thread Starter
engine smoke/vapor
My 1982 Westerbeke-44 blows out water vapor or white smoke starting when the temperature reaches about 145 degrees and levels off at about 170 degrees. These are the temps when the thermostat begins to open and is fully open.
The smoke/vapor goes no higher than about 6 inches above the water, and goes no farther than about 3-4 feet behind the boat at crusing RPM (2200).
There has been no loss of cooling water, although being on a sailboat, the engine isn''t used a lot.
Any ideas?
jeb1 is offline
post #2 of 4 Old 08-03-2002
engine smoke/vapor
isn''t there a problem with the pistons on that model. i believe there might have been a recall on that engine.
eric
kimberlite is offline
post #3 of 4 Old 08-05-2002
engine smoke/vapor
I noticed that "white vapor" on my Perkins M30 occasionaly, esp. when in fog or misty conditions. Worried about it for a while. Checked with a diesel mech. who said "don''t worry"
It is the same white vapor you see in auto exhaust when in cold, damp weather.
If it was white smoke and continued to drift for yards behind your boat, then worry.
clayton is offline
post #4 of 4 Old 08-09-2002
fer@fer's Avatar
engine smoke/vapor
Hi Jeb1
It sounds resonable to me the exhauts expelling together with hot water, some vapor too, particularly at lower ambient temperatures. Also when probably reaching 3.000 rpm or + you will get a lot more white smoke. The latter is more related to excess of force required to the engine.
As said by our colleague, 3/4 feet of white smoke should not be a bad new.
However, is quite difficult to distinguish a normal white smoke from an abnormal one. It seems that the difference is the quantity. The white smoke might come from a broken gasket or even worse a broken cilinder wall. In your case having heat interchanger, this should be clearly noted by the loss of cooling water. Which is not your case.
If the vapor is coming from water in the diesel fuel, then it also be noticed since it will produce starting and running problems.
fer@fer is offline
slight oil slick in diesel engine exhaust mcagney Gear & Maintenance 7 04-04-2013 01:15 AM
Atomic 4 is 4 lovers agent4change Gear & Maintenance 11 08-07-2011 05:14 PM
engine facing aft with saildrive installation levenezia Gear & Maintenance 3 01-16-2005 10:35 AM
Engine Removal drynoc Gear & Maintenance 4 01-04-2005 06:21 PM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
