Old 09-13-2008
Hobos is on a distinguished road
Raw water impeller
Lost a vane on my raw water impeller and it has moved in to the system Engine:Yanmar 3ym30. Impeller:Johnson, model 810b. Piece is about 7/8" x 1/4" Engine seems to be running at the right temperature and water is moing through the system. Should I take start taking things apart until I find it, or hope it has moved through.
Old 09-13-2008
capngregg's Avatar
Shaken-not Stirred
capngregg is on a distinguished road
Cool
I would not try to find the piece by disassembling anything major. If the piece were to get stuck in an undesireable place, it would probably be in the thermostat itself. If you've put several hours on the enine since the impeller change with no problems noted you're probably in the clear.
The missing piece will probably only make itself available at the worst possible time. Heat exchangers and thermostats usually catch the missing parts. A resulting problem may or may not be immediately apparent.
I'm sure there will be some more advise given shortly that may relieve your anxiety.
Good Luck!
Opportunity is missed by most people because it is dressed in overalls and looks like work.
T.A.E.
Old 09-14-2008
sander06 is on a distinguished road
If it ain't broke don't fix it. Wait until you're going to do a heat exchanger clean-up or thermostat replacement before searching for the errant piece of rubber impeller.
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
Raw water pump bestfriend Gear & Maintenance 56 04-26-2007 09:03 AM
Flushing/testing/preping an old water system on a new old boat tenuki Gear & Maintenance 8 04-19-2007 10:33 PM
Basic Thoughts on Tides Jim Sexton Seamanship Articles 0 11-17-2003 07:00 PM
leak from engine raw water siphon break i670684 Gear & Maintenance 2 08-11-2003 05:53 AM
Raw Water in Engine wmwtlw Gear & Maintenance 3 02-25-2001 11:31 AM
