what kind of furling system do I have? - Page 3 - SailNet Community
post #21 of 24 Old 09-19-2008
Originally Posted by ereuter View Post
I agree also that it might be a Hood Stream Stay with no wire headstay. I had one on my boat when I bought it, but your drum looks a little different.
If it is, there is a swivel at the top that attaches to the top of the mast. It allows the whole foil to rotate. These are prone to eventual failure (as mine almost did), because it there is a LOT of tension on that swivel.
The head of the sail would be attached to another swivel that rides up the foil, and your halyard attached to that.
I'd get up there and make sure that if there is a swivel attaching the foil to the mast, it is in good condition. Mine had separated by about a quarter inch, which was really scary. It also added friction, which made the sail hard to furl.
I took some photos of mine, but I can't seem to find them...
Eric
Dancamp,
Your system is a Hood Sea Furl Mark II. It is not a Hyde Stream Stay.
You do have a wire headstay. The "drum" you see on top is the halyard swivel.
When you get to the point of having to work on the system, PM me with a Fax # and I will send you the information.
knothead is offline
post #22 of 24 Old 09-20-2008 Thread Starter
boy, I'd love to get the info on this system, but I don't have a fax number. Maybe I can solve that problem somehow.
thanks again Knothead.
DanCamp
dancamp is offline
post #23 of 24 Old 09-20-2008
moderate?
camaraderie's Avatar
Dan...you could use the free trial here to get a fax:
eFax | Start Faxing FREE in Two Minutes
camaraderie is offline
post #24 of 24 Old 09-20-2008 Thread Starter
that faxing service wanted my credit card # for their free fax program. Kinkos works better for me now that I checked things out
but thanks anyway
dancamp is offline
Pro Furling System CC 37 Pilgram Gear & Maintenance 6 03-23-2004 03:04 PM
Battery Bank Design Kevin Jeffrey Cruising Articles 0 05-12-2003 08:00 PM
Upgrading Your Mainsail System Sue & Larry Her Sailnet Articles 0 11-17-2002 07:00 PM
Boom Furling Revolution Tom Wood Cruising Articles 0 07-12-2002 08:00 PM
Sailing with E-Mail Kathy Barron Cruising Articles 0 09-04-2000 08:00 PM
