Hull Delamination - Page 2 - SailNet Community
post #11 of 18 Old 01-03-2011
Interesting thread. I just found out from a survey that my boat has developed hull delamination issues. Repair by skinning the hull is cost prohibitive for a 30' boat that is 32 years old. Fastforward26, did you find a repair option?
runfast is offline
post #12 of 18 Old 01-03-2011
mitiempo's Avatar
He hasn't posted for 2 years so I doubt he is around here to read this.
What kind of boat do you have and how serious is the damage?
Brian
mitiempo is offline
post #13 of 18 Old 01-04-2011
My boat is a late 70's C&C built in the US. The hull showed a soft spot under the slings in the port quarter when it was hauled last year, and a surveyor diagnosed the problem. Also found a soft area in the starboard bow, and some gelcoat cracks elswhere suggesting the problem may be more widespread. Issues have been above the water line.
runfast is offline
post #14 of 18 Old 01-04-2011
Dirt Free
boatpoker's Avatar
What size and model and year is your C&C ? Most C&C's had balsa cored hulls which is an entirely different issue.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #15 of 18 Old 01-04-2011
pdqaltair's Avatar
I repaired a large area (15 ft2) area on a boat that got bruised by a stand and had damaged core, but only minor damage to either skin.
* Popped it out and repaired the damage to the outer skin. Very minor, just a little grinding and laminating. Easy to fair.
* Stripped the core from the inside and vacuum-bagged new core and inner skin. Not fair as glass, but about like original and hidden under the floor (but open for inspection). Fortunatly there were no bulkheads in the area (which, of course, is why it dented--incorrect blocking by the yard).
I used the boat hard for another 12 years and then sold her. Never a hint of a stress crack through the paint. Probably took about 15 hours of labor and $200 in material. The insurance gave me a check for $5,000!
Core replacement is not difficult. It takes good FRP skills and a plan. I was lucky in that the damage was under the bottom paint and I did not ave to match topsides; that is the labor intensive part, to me, unless you are refinishing the boat anyway. Of course, if the alternative is scrap, a quick coat of pain below the rail is not so hard.
Writing full-time since 2014
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #16 of 18 Old 01-04-2011
The boat is a 1978 c&C 29 mk 1. I'm not sure if the hull on these is balsa cored or not.
runfast is offline
post #17 of 18 Old 01-04-2011
mitiempo's Avatar
The surveyor should have stated whether it was cored or not. If not it would have to be a big hit I think to cause delamination.
Brian
mitiempo is offline
post #18 of 18 Old 01-04-2011
paulk's Avatar
We had a similar sized issue & fix with the starboard quarter on our 1981 balsa-cored J/36. I attacked it from the inside and was able to use gravity instead of vacuum-bagging to hold everything together. Messy and time-consuming, but only about $200 of materials.
paulk is offline
C & C 121 Customer Response to Manufacturers Post camaraderie Tartan 2 09-12-2012 03:54 PM
Ryobi vs. Makita vs. Poliglow?? CLucas Gear & Maintenance 61 05-05-2012 06:02 AM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Hull Speed Demystified Steve Colgate Buying a Boat Articles 0 06-10-2000 08:00 PM
