Old 09-15-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
Shower sump holding tank by-pass ????
Boat is a 78 Tayana 37, Shower is forward on port side, right now, the shower pan drains to a holding tank and once it full ( couple days ) ya flip a switch @ the panel and pump it OB
Question is, why can't the shower pan be plumbed directly to the bilge, by-passing the need for the holding tank & sump pump.
What an I not taking into consideration by doing this
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 09-15-2008
WinterRiver's Avatar
WinterRiver is on a distinguished road
Soap scum, hair, and other shower slime in the bilge? No thanks. That's a recipe for clogs and smells. The shower pan confines the slime and is easy to clean.
If you're trying to get rid of a shower holding tank, you could just pump overboard from the shower sump. Otherwise I don't see any reason to change the current set up. (If you have an urge to do plumbing work on a boat, mine needs plenty of help!)
Hylas 47
Old 09-15-2008
Be right there, right after I replace the sump pump I was trying to avoid replacing
1978 Tayana 37
Old 09-15-2008
Stillraining's Avatar
Handsome devil
Stillraining is a jewel in the rough Stillraining is a jewel in the rough Stillraining is a jewel in the rough
Pappy:
I agree with WR...especially if you have keel bolts or any thing like that in your bilge..Mine is rigged with a separate small bilge pump and flote inside a plastic battrie box that has been plumbed with two inlets one from the forward head and one from the aft.and then of course the discharge line with a check valve to a above waterline through hull.. Its an easy matter to clean , disinfect, deodorize,clean and or dry this small box. My bilge stays clean and dryer.
Old 09-15-2008
Yeah, I gotta agree with ya both, I was being lazy, hate to do something 1/2 assed after doing the blackwater side so cleanly
Ignore this thread
1978 Tayana 37
Old 09-15-2008
Handsome devil
Originally Posted by poopdeckpappy View Post
Ignore this thread
Oh no not another one
Old 09-15-2008
If you agree with them...why were you trying to get support for doing a half-assed job of it???
Ignore this thread
Holding tank or Fuel for Jeanneau Myblueheaven Gear & Maintenance 10 05-05-2009 01:37 PM
Holding tank location stoutwench Gear & Maintenance 17 04-11-2007 02:40 PM
Custom Holding Tank Mithril Gear & Maintenance 6 03-15-2007 03:48 PM
Holding Tank Questions John_colpitts Gear & Maintenance 14 08-31-2006 06:42 PM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
