09-17-2008
AFOC Stinkus Potus
Originally Posted by sailboy21
There is something about drilling a 1" hole and a series of 1/4" holes in a spar just doesn't feel right.... then trying to figure out how to route the cable through mast steps, bulkheads, settees etc... and 1/2" cable banging around inside the extrusion at anchor. No, quite happy with the radar mast. Plus it gives the GPS antenna and boathook a nice place to perch.
There's probably tons more holes your mast already with the various cleats, spreaders etc. already attached so I wouldn't think a few more would be an issue, however, the cable routing?? I can see your point. It was just a thought  . As for the Aluminum pipe, I think if it were me I'd either step up to 2.5" schedule 40 or schedule 80. Another option (if you can route the lines) is to find some way to stay the pipe to eliminate some of the flexing.
Chris
S/V "The Jade Dragon"
1975 O'Day 25 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Meet me at To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Ignore Power = Currently Rebuilding
