09-17-2008
Just leaking
Hello all, if you recall I am in the process of getting my Westerbeke L25 motor going again. First, I had a thread on the starter motor and finally got the orignal rebuilt for a mere 600.00  Next, the fuel tank was swimming with bugs and who knows what else so, drained and cleaned and filled with fresh diesel. Changed both the racor and fuel filter on motor. Bleed the entire fuel system and now she starts and sounds good only, I now have a fuel leak well, not a drip but a good stream. Took awhile to narrow down where it was comming from but last night I found it. The problem and question I have is there is what looks like a bleeder bolt, I loosend this bolt during the bleed process and found it to be what looks like a plug, no treads just smooth metal and about the size of a penny around, and about a half of an inch long. I looked at the manual I have and it just show a bolt head on top. Oh this bolt is on top on the injector pump. This is not a high pressure part of the system. I was wondering if there is supposed to be an o ring or something to keep this from leaking? I did not see one when I removed it. I am very leary of using any type of gasket maker in the fuel system or is this what I need to do. Hope to get some insite and I know I need a pic will try this weekend.
