Old 09-17-2008
Marcvet is on a distinguished road
Paint for boom blisters
I have a few small areas of blistering on my aluminum painted boom. I plan on sanding the aluminum down to bare metal and refastening any bits and pieces with plastic washers. What I would like some advice on is what coatings to put on the bare metal to bring the surface back to match the rest of the boom.
Thanks,
Marcvet
Old 09-17-2008
You could fair the surface with thickened epoxy and then paint over it after sanding it.
Old 09-17-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
How well will epoxy stick to aluminium?!?
..I'd have thought any tiny amount of oxide under the edges would cause it to just crack off.
Cameron
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 09-18-2008
sander06 is on a distinguished road
You should use something like Lanocote on the threads of the stainless steel screws that are penetrating the aluminum mast. Unless you have major structural issues in the blistered areas, I'd sand the hell out of it and call it good. Coat the mast with some decent paint and the pitted areas will be virtually invisible. It's not like this paint job is going to last forever.
"There's a wind in my sails that protects and prevails." - "Six Months in a Leaky Boat", Split Enz
Paininting non-skid... marinesniper Gear & Maintenance 36 01-29-2008 01:10 AM
The Bottom Paint Blues Don Casey Gear and Maintenance Articles 0 06-22-2003 08:00 PM
How to Paint Your Own Deck Don Casey Gear and Maintenance Articles 0 02-04-2002 07:00 PM
Bottom Paint Compatibility Dan Dickison Gear and Maintenance Articles 0 01-24-2001 07:00 PM
Paint the Bottom Yourself Tom Wood Gear and Maintenance Articles 0 03-09-1999 07:00 PM
