Holding Tank Vent Filters - Page 2 - SailNet Community
post #11 of 15 Old 09-19-2008
Closet Powerboater
MedSailor's Avatar
My fiancee just attended a seminar on marine plumbing during which the lecturer addressed your question. He suggested putting two vents, or a "T" in the vent fitting and running a vent outlet to each side of the boat. The laws of physics and wind will ensure that the smell comes out the leward vent and is carried away quickly.
Hope that helps.
MedSailor
MedSailor is offline
post #12 of 15 Old 09-19-2008
The T-fitting and two vents will also help draw air out of the tank due to venturi effect of air flowing through the two vents... windward to leeward.
sailingdog is offline
post #13 of 15 Old 09-23-2008
I have had a similar problem in the past and was solved with a sealand filter. Also a treatment for the holding tank a few times helps alot with any build up in the tank that or course adds to the smell!! Basically this helps to give the holding tank a good clean out.
Not a strange thing to change pipes and still have the smell.....only to have a tank that needs a good clean - I learnt this by the second year I had been living on my boat.
What I have tried (and worked for me) is to put a lot of hot soapy water (liquid washing up detergent, a small amout!) through your toilet and pipes and a good soaking...basically a good cleanout of the pipes and tank.
Pump out - do it all again a few times if possible.
Add the sealand filter and if all piping is ok this will go a long way to solving your problem
draphael is offline
post #14 of 15 Old 02-12-2009
I would like to hear how bid a deal it is to change the charcoal in the filter. One over flow of the tank = $85 for a new filter
motion300 is offline
post #15 of 15 Old 02-12-2009
Replacing carbon in a filter....
Found this on another site. I looked at putting in one of these filters but would not pay $80 a year. This is the way to go.
http://www.clubsearay.com/forum/showthread.php?t=849&highlight=recharge
gtod25 is offline
Holding tank thruhull vent Sixbrothers Gear & Maintenance 20 05-20-2008 03:27 AM
Holding tank vent on transom? groundhog Gear & Maintenance 4 06-19-2007 07:16 AM
Holding tank vent.. groundhog Gear & Maintenance 9 06-18-2007 07:37 PM
Custom Holding Tank Mithril Gear & Maintenance 6 03-15-2007 03:48 PM
Holding Tanks Tom Wood Gear and Maintenance Articles 0 06-10-1999 08:00 PM
