09-21-2008
Don Radcliffe
You can test the panel with just a multimeter, if it has amps as well as volts. As you said, the open circuit voltage should be 17-19 volts in direct sunlight. If you put the ammeter directly across the leads, you will read short-circuit amps. The amps the panel will put into a battery are typically about 80% of the short-circuit amps.
