Is AC power really needed on a boat that never sees a dock? - Page 2 - SailNet Community
post #11 of 24 Old 09-23-2008
i have a friend with a 32' junk rigged schooner, steel hull, ocean going vessel, been all over, and he cruises with only 12v, as would I if one day we decide to have electricity at all.
shore power? a few solar panels tops off all the junks batteries year round at the marina, even here in the pacific NW.
we think we need much, much more than we really do. this is one of the small issues the planet currently is struggling with.
cheers, jan
nikolajsen is offline
post #12 of 24 Old 09-23-2008
Very good advice. Too many people think everything is a must have when in reality it's just fluff.
When I sat up my first bigger boat I had a humongous list of MUST-HAVE items, and after getting everything set up, figured out that if they didn't work, I didn't miss them.
I don't have AC on my current boat, no need for it and don't miss it in the least. If the next owner wants it, he'll figure out where he can get it.
The reason to set up a boat is for your own enjoyment, if you want it or need it, install it, if not, don't worry about what the next owner wants.
Going by all the "d&*^ PO" comments on the boards, no-one is able to install anything correctly, and they'll have to upgrade it anyway, so save them the trouble and let them start from scratch.
Ken.
merc2dogs is offline
post #13 of 24 Old 09-23-2008
there you go!
jan
post #14 of 24 Old 09-23-2008
Once known as Hartley18
Classic30's Avatar
Dock
Sure, if you don't have an AC system installed and you don't need one, then you'd be silly to fit one.
The point in this case is: If you've already got a shorepower inlet + wiring + outlet(s) + holes in cabin for switches and wires, you might as well rip out all of the old crap and install a bare-bones AC system which is what has been proposed here. This will be both useful on occasion, and likely increase the price of the boat when sold.
Patching up holes left by an old AC system is never easy, pretty or unmistakeable.
Cameron
Classic30 is offline
post #15 of 24 Old 09-23-2008 Thread Starter
'72 Pearson 36
SVDistantStar's Avatar
Send a message via AIM to SVDistantStar
Well ive got holes where outlets used to be, but the outlets went into the trash as did the wires. I got a used Newmar switch panel that has both AC/DC on it, so i will probley put in at least 1 or 2 outlets somewhere.
1972 Pearson 36 S.V. Distant Star
SVDistantStar is offline
post #16 of 24 Old 09-23-2008
tommays's Avatar
If i understand there is no motor ?
Just wondering do you move the boat buy sail only ?
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
post #17 of 24 Old 09-24-2008 Thread Starter
'72 Pearson 36
Ive got a bracket on the back of the boat for an outboard. You can see it in my sig pic. Ive got a 9.9 longshaft motor that i use on it right now, but used to have a 40hp Evinrude on there. Or if i dont have the outboard on the boat, ill use my skiff tied along side to move it.
post #18 of 24 Old 09-24-2008
DistantStar,
Presumably you're going to want a live AC recepticle for power tools when you work on your boat. Or is everything cordless these days?
sailhog is offline
post #19 of 24 Old 09-24-2008
Distant Star-
If you don't use AC, you don't need AC, and if you have no inverter hardwired into the boat, you don't need to provision AC outlets at all. On the other hand, the resale and convenience points are real, and the cost of doing a minimal AC installation--and doing it right--isn't going to add much to THAT monster project.
You can certainly stick an AC inlet (with GFI as close to it as possible) in the cockpit somewhere. Then just run one good run to a double breaker at your electrical panel (and many boats just add a separate AC breaker panel, so it can' t be confused with the DC breakers at all) with one good double socket next to that. That's "good enough" and clean and cheap and simple, you can always run an extra leg forward from there when and if you want to, or if you want to gussy it up to sell it sometime in the future.
Or, simply leave that little extra space next to the breaker panel, and know that if you change your mind, you can come back to add AC.
I feel the same way: On a mooring, don't need it. On the hard or an overnight transient dock? Extension cord. "Good enough for gummint work". Stick the AC on the back of the ToDo List, wait till you get down that far.
hellosailor is offline
post #20 of 24 Old 09-24-2008
Classic30's Avatar
Dock
Sure, if you don't already have some form of AC system installing one is probably not high priority on the ToDo list, but connecting up the shorepower whilst on the hard and using your AC outlets for power tools is not only neater and more convenient, it could also save your life.
Extension cords down hatches and companion-ways can be serious trip and fire hazards and can be lethal if accidentally cut through..
The Joys and Pitfalls of Buying a New Boat - Part 1 Lin & Larry Pardey Buying a Boat Articles 26 01-12-2015 11:59 AM
The Search for the First Boat - long learning curves pmoyer Boat Review and Purchase Forum 45 12-20-2008 02:28 AM
Construction of a PVC (Divinycell) cored boat Giulietta Sailboat Design and Construction 8 10-19-2007 06:46 PM
Electrical Power on Board Kevin Jeffrey Her Sailnet Articles 0 02-11-2003 08:00 PM
The Art and Science of Fendering Sue & Larry Learning to Sail Articles 0 02-27-2000 08:00 PM
