Thought I would post up an idea I am trying out. I do not enjoy the hassles I have to go through to remove cushions and then the boards that support the seating. I find it awkward to have a two-step process and the supporting boards are for the most part to large to just set anywhere. Additionally it makes it a hassle to get under the cushions to get one item and have to remove two cushions etc...
So I took this:
Using the cushions placed on the on the boards - painters tape is used to mark the dimensions of the new frames.
I cut out frames that would sit in place and measured for the size of the cushions. I took 1/4 inch off the measurements of the original board slat dimensions to compensate for batting, compressed foam and the new vinyl. Then using mat roving stapled to the underside of the frames. The vinyl will be stapled on the underside inner portion of the frame.
Here you see the tops of the new seating frames. Spare white marine vinyl was then cut to affix to the tops. This was to prevent resin from soaking through to the plastic, as well as for rigidity.
Then these were flipped over and resin and additional re-enforcing cloth was added...Picture above is the application of the resin...
Luckily - since I own a sewing machine but have not really learned how to use, Dana is sewing the cushions...
We are using a $80 sewing machine - works well:
This is one of the cushions about ready to be installed into the new frames.
Will post the completed project once all done. Hopefully this works the way I intend and now can get easier - one cushion remove access to everything. The old cushions needed to be redone anyways. Plus, weight savings...the new framing is about 1/2 the weight of the solid wood...
The saloon seating will be two tone and color selections are a dark chocolate with light tan accent. Additionally, the cushions for the buttocks will now be 6 inches instead of four which will make sleeping and relaxing in the saloon more enjoyable after a hard day of sailing. Marine vinyl was selected since it is the easiest to clean and repels water and odor better than micro and the other outdoor fabrics of which nothing I could find suited my tastes....
