Winter Covers? - Page 3 - SailNet Community
post #21 of 90 Old 10-25-2008
Maine Sail's Avatar
Sorry K1...
Originally Posted by k1vsk View Post
Why would anyone say something like that implying I don't know what I'm talking about?
I've lived in New England for 61 years (so far), most of which as a boater, so I am not "clear" how I can not "clearly" have any experience... Perhaps you can see the snow in the picture?
Back to the issue -
The boom tent shown has a connector to cover the deck fwd but with the dinghy there, the surface area remaining is negligible and in 40+ years (with various boats), so far, so good... no damage from condensation or anything else and, in this case, the deck (non skid) is Awlgrip, as is the topside, so I am particularly keen on proper covering.
As a practical matter, it is quite difficult to completely insulate a boat from moisture as thoroughly enclosing it so as to preclude ventilation only serves to promote condensation, both within the boat as well as it's exterior. The Awlgrip serves to complicate the equation as it is essential it has ventilation space.
K1,
Sorry my bad. I should know by now never assume!! I'm such a schmuck.. I checked your profile and it did not list a location. I then clicked your photo and got an error message. It worked this time and I see you are from RI and I see the snow. When you said boom tent that is NOT what I envisioned. That is about a 70-80% cover! I pictured a 15-20% cover only over the cockpit and some of the cabin..
I guess there is a difference between Maine and RI weather. Up here with a dark green hull if you don't cover the decks the temp swings from day to night and the solar gain on a dark hull will create actual precipitation inside boats with snow on decks. I looked at an Ericson 38 three years ago that was a virtual science experiment and it was literally snowing inside in it's own micro environement. Annie Gray my broker had never seen it snow in a boat and I had not either. i have seen it snow in my tents during winter expiditions but that was my first experience with snow inside a boat.
She had over two and a halff feet of snow on decks at a constant 32f. The the sun would come up and heat the top sides warming the interior into the 40's or even 50's while the deck was still at 32 degrees.. To make a long story short it was for sale and this was the first year it was uncovered. By April, whe I looked at it, the boat and iterior wood work was severly damaged and water stained. The foam backed headliner was so saturated with condensation that it colapsed and blew out zipers in some areas...
Now I'm sure it did not help that the boat sat facing SE near the waters edge and saw early morning sun on the hull after very cold evening temps
You're boom tent covers a lot but and I'm sure works fine with the weateher you guys see. It is very rare to see a boat up here without full coverage but by the time you hit MA some actually sit uncovered.
Our 2005 Catalina 310 sat uncovered at Eastern Yacht Sales in Hingham and it did condensate when snow was on deck. Once we closed the deal I paid to have it covered for four months.
If your decks are Awlgrip it's not a good idea to let snow sit directly on it. If you can, try to brush it off the foredecks. For short durations with dry outs in between you'll be fine..It's really much worse with deep snow as the hydraulic pressure from the weight of the snow can force moisture through teh paint causing blisters and bubles.
I was guessing you were from SC or somewher that never sees snow and you had a small boom tent.. Sorry for teh confusion.
P.S. You might consider updating your profile...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #22 of 90 Old 10-25-2008
Maine Sail's Avatar
Now that you ask, I looked in my boat files and it was Thurston (in RI)
Neil Thurston does very good work!! He's one of the good guys..
______
post #23 of 90 Old 10-25-2008
Detachable member
wchevron's Avatar
he just priced a dodger for me about $2000 for dodger & new frame. is this reasonable. never bought a dodger before.
wchevron
s/v Time Flies
'78 C-30
wchevron is offline
post #24 of 90 Old 10-25-2008
Maine Sail's Avatar
Can you give me the specs? It's hard to tell without knowing what he quoted as there are soooo many options with dodgers..
______
post #25 of 90 Old 10-25-2008
Sea Slacker
FWIW my boat's winter cover is a couple of large tarps over a frame made of EMT tubing (I'll probably use sched. 40 plastic tubes next). It ain't pretty but hopefully will keep the precipitation out (though I bought presumably heavy duty tarps online and they turned out to be kinda mediocre).
brak is offline
post #26 of 90 Old 10-25-2008
Owner, Green Bay Packers
Wow! I cannot imagine not covering the whole boat here in Michigan. I've done without and inevitably ended up with damage due to my negligence. The freeze thaw cycle will find any deficiencies in watertight integrity and make them into a more serious problem. I really don't want to get into the bone headed decision that led to my leaving the boat uncovered last year for a good portion of the winter. The money spent this spring was nothing as compared to the amount of time I spent for such laziness and stupidity. "Just a little rain" has a way of changing into "aw shucks" or maybe something a bit stronger. My hair hurts thinking about it.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #27 of 90 Old 10-25-2008
Brak-
Depending on where you live, it might be better to stick to the EMT, since the PVC Sched 40 pipe gets a bit brittle in cold temperatures in my experience.
sailingdog is offline
post #28 of 90 Old 10-25-2008
Sea Slacker
Brak-
I am on Chesapeake, it is not cold enough for that around here. I used 3/4" EMT previously but it is a bit tough to work with. I used 1/2" this year - easy to work with but not as sturdy.
Plus, with PVC there is a better variety of connectors - for example there is a 4 way socket, so I can easily make connections on top of arches for the forward-back rib, there are angles etc.
Anyway, I am not set on that - gotta go through this winter first.
brak is offline
post #29 of 90 Old 10-25-2008
Oh, so you don't have a real winter... just a bit of slightly cooler weather...
post #30 of 90 Old 10-25-2008
Sea Slacker
I know, I know. However - it occasionally gets frosty - my main concern is gelcoat. While in general in excellent shape (for 36 years old anyway) it does have cracks here and there - they are all tiny, but let the water get in there and freeze a few times, and it will be a much bigger problem. So - gotta cover anyway.
I am sure people up north have much more serious potential problems - I almost feel ashamed butting into this discussion
brak is offline
Emergency portlight covers GoodOldBoat Good Old Boat 6 03-02-2013 02:14 PM
Winter Storage Issues Joy Smith Gear and Maintenance Articles 0 10-26-2004 08:00 PM
Winter Storage Joy Smith Gear and Maintenance Articles 0 10-22-2003 08:00 PM
Preparing Your Boat for Winter Bruce Caldwell Gear and Maintenance Articles 0 11-03-2002 07:00 PM
Winter Covers bjoc2314 Gear & Maintenance 2 10-16-2002 03:51 PM
