Winter Covers? - Page 4 - SailNet Community
post #31 of 90 Old 10-26-2008
Last year made a frame of 4" PVC for the ridge, supported by 2" PVC vertical struts, then high-pressure sprinkler hose for the ribs. Used four tarps to cover her. The tarps did not work well, so this year we're trying a pool cover on the recommendation of a fellow club-member.
Jim
SEMIJim is offline
post #32 of 90 Old 10-26-2008
boy at this expense you would think pulling the mast and using an indoor boatel might be cheaper. of course i am right by the inner harbor and my boat will be wet all winter, just a few sweepings to get the snow off. i might need to make 5 trips, and the harbor has not frozen but once in the last 50 years
scottyt is offline
post #33 of 90 Old 10-26-2008
Is anyone able to post photos of their homemade pvc or emt structures? I'm planning to design and construct something along those lines and cover it with heavy duty tarps. Advise on good or bad online tarp vendors is also welcome.
Thanks
CapeAnnBristol is offline
post #34 of 90 Old 10-26-2008
Owner, Green Bay Packers
Thanks
I don't doubt that you can find tarps on-line but in most areas you'll find someone selling them inexpensively. In my case, there's a discount tool outlet nearby that also serves as "tarp and glove world". As mentioned above, swimming pool companies will be able to tell you where to get large sized visqueen although I think a tarp will work better. A local roofer would be able to provide you with information on where to get large tarps.
There were photos of someone's emt structure here last year...he was a tube bending whiz! I assume you've seen my earlier link to how to build a pvc structure. There's no reason that structure has to be mounted on deck either; you could build the base frame work on the ground.
Be sure to buy a pvc tubing cutter of the ratcheting scissors type...it'll make things go inestimably faster. And label the various tubes and fittings....no, you won't remember where they go a year from now. (g)
You might also want to have a grommet making kit on hand; that way you can add holes to your tarp where they're needed. You can get quite a few years out of a tarp if it's not flapping around.
Wm. F. Buckley, Jr.
sailaway21 is offline
post #35 of 90 Old 10-26-2008
Here ya go: Index of /misc/sailboat/Abracadabra/Tarping
This year I'm going to add a strap length-wise along the ribs on each side and cargo netting between the ribs to reduce sag in the cover.
Tried that last year, despite the many recommendations against it. It did not work out well. Oddly enough, for all the reasons I saw it anti-recommended
Jim
SEMIJim is offline
post #36 of 90 Old 10-26-2008
Hamilton Marine has some pretty good tarps at reasonable prices...
sailingdog is offline
post #37 of 90 Old 10-26-2008
As I mentioned earlier: A fellow club-member has found swimming pool covers to work nicely. We just ordered one 40' by 16', "medium" duty, for $88. He uses super-balls, short pieces of line with loops at each end and adjustable bungee cords to hold it down. He uses those foam blocks shrink-wrappers use to keep the lines from chafing the hull. He puts a line all around just under the rub rail and keeps that tight with a bungee, to keep the wind from getting under it and blowing it out.
You're probably talking about TrueBlue. Here are the pictures: I designed and fabricated an EMT
And here's the thread, from last year, in which I found the link: Winter cover up
If you use grommets, make sure to duct-tape the inside, or they'll do Evil Things to your hull, no matter how well you think your tarp/lines are tightened. Ask me how I know . Plus, grommets are prone to ripping out.
Better to use the super-ball method or grip clips.
Jim
SEMIJim is offline
post #38 of 90 Old 10-26-2008
SEMIJIm-
Good point about taping over the grommets...they can do a job on the hull finish if you don't, and again... DON'T USE THE GROMMETS. They will tear out if you have the tarp tensioned properly. Use the superball and cord or grip clips...
post #39 of 90 Old 10-26-2008
Detachable member
wchevron's Avatar
i used 1/2" emt last year to build a frame and bought some tarps from home depot. i used 3 tarps for my 30'er. one went from the stern to the mast on the port side, one from stern to mast on starboard, and one from mast to bow. with all the rigging, it wasn't a very tight fit around all the rigging but it probably kept out about 90% of the snow and worked pretty good.
wchevron
s/v Time Flies
'78 C-30
wchevron is offline
post #40 of 90 Old 10-26-2008
Detachable member
wchevron's Avatar
i used all the grommets on the tarps last year and didn't have a problem with any of them tearing out although there were some marks on the hull where they rubbed over the winter. those buffed out this spring but this year i'm going to cover them with something.
wchevron
s/v Time Flies
'78 C-30
wchevron is offline
Emergency portlight covers GoodOldBoat Good Old Boat 6 03-02-2013 02:14 PM
Winter Storage Issues Joy Smith Gear and Maintenance Articles 0 10-26-2004 08:00 PM
Winter Storage Joy Smith Gear and Maintenance Articles 0 10-22-2003 08:00 PM
Preparing Your Boat for Winter Bruce Caldwell Gear and Maintenance Articles 0 11-03-2002 07:00 PM
Winter Covers bjoc2314 Gear & Maintenance 2 10-16-2002 03:51 PM
