09-24-2008
Solid PVC pipe is a really bad idea on a boat, as it tends to break under the vibration and movement that it normally is exposed to on a boat.
Use a high-quality marine sewage rated hose, like Sealand OdorSafe or Trident 101, and you should be fine.
