Cabin Heat - Page 9 - SailNet Community
post #81 of 87 Old 10-02-2008
the pointy end is the bow
erps's Avatar
We don't have a day tank in our application. We have a low pressure pump plumbed in to the main fuel supply line after the Racor filter. It's convenient. I don't worry about how to manually transfer fuel from one container to another. I still spill milk at the dinner table when filling my glass so a day tank for diesel wouldn't work for me.
SteveCox's suggestion sounds interesting too, depending on how often you run your motor.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
erps is offline
post #82 of 87 Old 10-02-2008
Valiente's Avatar
Originally Posted by Hartley18 View Post
Aside from the risk of water getting in (assuming the reason you're using the heater is that it's wet and cold), I'd think re-filling the day tank from the comfort of a warm and cozy cabin would be much more pleasant.
We're talking the Pardeys...their ideas about convenience aren't necessarily the same as yours and mine. I view their DVDs as part "great ideas!" and part cautionary tale.
Valiente is offline
post #83 of 87 Old 10-02-2008 Thread Starter
Handsome devil
Stillraining's Avatar
I might have as many stoves in my garage as Mainsail has anchors in his by the time Im through with this...
Stillraining is offline
post #84 of 87 Old 10-02-2008
Freesail99's Avatar
Originally Posted by SteveCox View Post
I have seen some diesel day tanks plumbed to the return from the engine to the tank. The return line goes from the engine to the tank and when it is full there is a return line to the main fuel tank that way the day tank is filled every time you run the engine. It seemed pretty convenient to me.
Installing it this way will mean you don't have to bleed this system. This is the preferred way to install an oil heater in a home.
S/V Scheherazade
Freesail99 is offline
post #85 of 87 Old 10-02-2008
Once known as Hartley18
Classic30's Avatar
Dock
I'd worry about doing this on a boat though.. it means you have pressurised fuel lines (not much pressure, but still some) running within the cabin.
Any sort of leak is not only the mess it would be at home - in the confined space of a yacht it could empty your fuel tank (leaving you stranded someplace) and be a lethal fire risk if mixed with the wrong sort of automatic electric bilge pump..
Cameron
Classic30 is offline
post #86 of 87 Old 10-02-2008
Classic30's Avatar
Dock
Originally Posted by JohnRPollard View Post
Unless you spilled!
Therein was the only real downside to bulkhead/cabin mounted diesel/kero heaters from our perspective: Potential odor from unburned or spilled fuel.
Kero wouldn't be too bad - after all, that's what they use for dry-cleaning.
Diesel would be problem though.. particularly on nice new cushions!
Cameron
post #87 of 87 Old 10-02-2008
Freesail99's Avatar
To be honest with you I don't think it is really pressurised at all. I can't recall ever even hearing a hiss or the fuel spraying in any way if I had to remove a line from the system and broke a seal. All it is, is a loop. You'll get more spill and smells without it.
S/V Scheherazade
Cabin Heat during the Winter Gulfislander Gear & Maintenance 10 11-06-2007 05:39 PM
Proper Cabin Lighting Tom Wood Gear and Maintenance Articles 0 02-24-2003 07:00 PM
Heat Emergencies William Mahaffy Seamanship Articles 0 12-18-1998 07:00 PM
Heat Emergencies William Mahaffy Her Sailnet Articles 0 12-18-1998 07:00 PM
