09-25-2008
If the sole is wood, you really need to seal the entire piece of wood, that includes the bottom and sides... otherwise anything you put on it as a finish will lift off as moisture migrates through the wood. As SF said, epoxy is a good choice for sealing the bottom and sides... and even the top...and then you can varnish/paint over the epoxy.
