Old 09-26-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
Energo-Tec
Has anyone tried Energo Tec AC/DC generator? It is an standard alternator that replaced the one on the diesel engine and has an electronic box. It produces upto 4KW of AC power to operate perhaps marine aircon, washing machine etc... ENERGO-TEC 220V POWER SUPPLY
essentially its making the onboard diesel engine as generator.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 09-26-2008
camaraderie's Avatar
moderate?
Way to big an alternator for a standard marine diesel. Quick way to lose your bearings unless a custom mounts was designed with dual belts and pillow block to cut the side loading.
Straight conversion would make 4kw about 6 hp and with the losses involved you's probably be looking at 10HP used.
I think this system is probably designed for much larger marine engines.
Old 09-26-2008
Oh, didn't realise that it works out to equivalent of >333amp on 12V. That's a pretty heavy load.
Cam, thanks for pointing it out.
Ken
Old 09-26-2008
I33 I33 is offline
I33 is on a distinguished road
Too Much!
Too much of a load on your engine, too much money at $2500! You can find good used 4-5kw diesel gensets in that price range.
Gil
s/v Truthsayer
Old 09-27-2008
Yup! sometime its is easier to see clearer when someone points it out. cheers!
Ken
Old 10-20-2008
SelkirkGrace's Avatar
Multihull Fanatic
SelkirkGrace is on a distinguished road
Talking Snake oil?
I guess I would like more data about their "solution."
The alternator they show in their diagrams is (or looks exactly like) a standard GM/Delco alternator and these typically have an output between 50 and 90 AMPS (police special version). Given that the alternator should fit on any marine diesel (thus it cannot be oversized more than 25%), it would have to be way oversized to put out their rated current (as Cam said). So I ask myself, what are they doing to achieve this? Alternators typically put out something higher than 15V and are regulated to 13.8V. So, the output voltage of the alternator does not appear to be the answer. Is it possible they are generating multiphase power and then somehow summing it, producing a DC current load?
If I were going to pursue their solution and without calling it "snake oil", I would want a significantly better technical explanation than is on their website.
Outboard Motors E TEC verses the others dsbentley Gear & Maintenance 4 05-24-2006 08:26 PM
