09-27-2008
Do you have a CAN bus on your boat? I seriously doubt it... most sailboats don't use a CAN bus.  If you don't have a CAN bus on the boat, you won't be using Pins 7-10.
Pins 1-3 are used for an alarm relay. If you don't have one, you don't need to use those pins either.
