Switching battery banks with engine running - Page 5 - SailNet Community
post #41 of 67 Old 09-30-2008
Omatako's Avatar
Originally Posted by hellosailor View Post
Don't know how to tell you, Andre, but both of those switches ARE ROTARY.
I guess in the purest form you are correct, they are both rotary but they are definitely not the same. The implication that SD (I'm sure) and I were discussing is that the lower of the two can be turned a full 360 degrees, starting from anywhere. That is, one can start from ALL and turn it clockwise through OFF to battery 1 or from battery 1 thru OFF to battery 2.
The top one is not the same. It goes from OFF thru 1 to ALL to 2 but then it has to be turned back clockwise to return to OFF. It cannot continue anti-clockwise to OFF again. The implications for your alternator is that it takes a conscious move to turn it off, not an accidental move in the wrong direction.
From the "STOP ENGINES" warning label on your switch, it would appear to be the most dangerous kind--the kind that does not "make before break".
When it is turned from OFF to any other position it is make-before-break. The only place it does not "make" is in the OFF position for obvious reasons . The stop engines label is just a warning not to turn the power off while the engine is running, nothing to do with the direction the switch turns in. The same result will be achieved on either switch but it doesn't make the top one more dangerous.
Arthur C. Clarke
Omatako is offline
post #42 of 67 Old 09-30-2008
Or, you could just use an echo charger or battery combiner and a Blue Sea Dual Circuit Plus battery switch.
Originally Posted by davidpm View Post
Not saying the following is right or OK but what we do is.
Start engine on 1 (starting battery). If engine starts switch to All to change both batteries while motoring to channel.
Turn off engine and switch to 2 (House bank).
Before starting engine switch to 1 (starting battery)
This is old-school keeping one battery for starting and one for house but requires switching from 1 to All while running.
The only dangerous step is to remember to switch the battery after changing on all. If you leave it on all and run your GPS, Lights etc too much you could kill both batteries and not be able to start.
So to protect against this we keep a changed NAPA starting battery under a bunk just in case. It will start the engine we have tested it.
sailingdog is offline
post #43 of 67 Old 09-30-2008
Originally Posted by GBurton View Post
The label says to stop engines before turning off, not turn off engine before switching....
Idly wondering how one might stop an engine w/o turning it off...
All kidding aside: Other than Steve's one scenario (hadn't thought of that one, Steve), I can think of no good reason to switch the switch while the engine's running. So why tempt fate? Secondly: None of them I've seen have a lock-out that prevents you over-traveling from "1" or "2" into "OFF," so, again: Why tempt fate? But they're your alternators. Me: I'm going to play it safe.
Jim
SEMIJim is offline
post #44 of 67 Old 09-30-2008
SEMIJim-
Most marine diesels aren't going to be affected by shutting off the electricity to them, since they aren't dependent on an electrical ignition system—they're diesels... so to stop them you need to cut off either the air or fuel.
Jim
post #45 of 67 Old 09-30-2008
SEMIJim-
Which is how you "turn them off."
I think you misinterpreted the nature of my musing
Jim
SEMIJim is offline
post #46 of 67 Old 09-30-2008
Ah ...you’re just being obtuse aren’t you
Jim
GBurton is offline
post #47 of 67 Old 09-30-2008
Moderator
JohnRPollard's Avatar
Jim, per your question below. Steve mentioned a scenario where you might want to switch the battery selector while motoring. There are others.
In some instances, both batteries may be nearly depleted, so both are needed to crank the engine over. Normally you would want to recharge them both while running the engine for as long as necessary. But there could be circumstances where you cannot or will not run the engine for very long (short hop, low on fuel, overheating condition, etc). In a case like that, it would be better to give one battery the best charge that you could during the time the engine is running, rather than under charging them both. So you'd switch once the engine was running.
I can think of others, but you get the idea...
Maybe I'm missing something obvious (it wouldn't be the first time), but why would you need to do this? By "this" I mean: Switch battery use while under way under motor?Jim
Originally Posted by SteveInMD View Post
I agree for the most part. I can see needing to switch if you totally run down one battery and the other is partially discharged. You may not want to risk combining them with the battery switch prior to cranking the motor. If you did, the one battery with a partial charge would be trying to charge the dead battery and crank the motor at the same time, which is at best very hard on the battery and at worst will leave you with no ability to start the motor.
The practice of using one battery at a time is old school. The modern thinking is that you should use both at the same time. Your batteries will last longer if you discharge them both a little than one a lot. You should either have a dedicated starting battery, or a monitoring system, or know your usage well enough to not get yourself in trouble, or all of the above.
JohnRPollard is offline
post #48 of 67 Old 09-30-2008
davidpm's Avatar
Are you saying an install could benefit from both? How.
They look similar in function.
davidpm is offline
post #49 of 67 Old 09-30-2008
Charter Captain
harryrezz's Avatar
Location: Buffalo, NY (warm months), Liveaboard in Caribbean (cold months)
Wow! Can't resist chiming in on this one ....
Two key points are rattling around here, but are being missed, probably because we all have diffeent boats with different setups.
First - if your boat is set up with more than one battery YOU SHOULD NOT USE THE SAME TYPE OF BATTERY IN BOTH CIRCUITS!!! You should use a "Starting Battery" in one and a "Deep Cycle" battery (or batteries) in the other. They are VERY DIFFERENT. The "starting" type is designed to give out, in simple terms, a big burst of power for a short time - such as is needeed to start the engine. That's why they are rated as having a high number for "Cranking Amps", and a relatively low number for amp. hours. It is NOT designed to be deeply discharged and then recharged over and over. This will cause the plates to deteriorate very quickly and premature failure will result.
The second curcuit should be used as a "house" circuit, and should be used to power everything else on the boat. Here a "Deep Cycle" battery should be used. They are designed in a very different structural way and are designed to give out a smaller flow of power over a long time. Most do not even have a "Cranking Amp" rating, becaus e that's not what they are for - but they have a relatively high amp. hour rating. They "don't mind" being deeply discharged and recharged over and over ... that's what they are built for ... but they do NOT like to have to put out a big burst of power.
It's simple, really - use a "Starting Battery" for starting and a "DeepCycle" battery to power everything else! Hence the multi-position switch. Set the switch to "1", the Starting Battery, and start the engine. Then switch to "Both" while the engine is running to ensure that both are fully charged. (Note - if you have the proper type of batteries set up DO NOT start the engine in with the switch in "All". Doing so will "ask" that Deep Cycle battery to do something it is not designed for.) After you shut down the engine, move the switch to "2" and the Deep Cycle battery(s) will be the only one(s) connected and will power your accessories. When it's time to re-start the engine, move the switch back to "1", and repeat the above.
In this way you will be using each type of battery as it was intended and you will not only gain optimal performance from both battery banks, you will also get MUCH more servicable life from your battery investment.
BTW - for those of you with only one battery, you should be using a "Dual Purpose" type battery. It won't have quite the cranking amperage of a true "starting" battery, but it will do the job perfectly well, and it will tolerate many more discharge/charge cycles before it goes bad than would a "Starting" battery.
"Automotive" batteries are all "Starting" types in their construction and are not intended for use in boats where they will be asked to deliver power over long periods. This is borne out ny noting that if you even leave the dome light on in your car overnight it will kill the battery!
Uh - in case you hadn't noticed, using your electrical system properly - by which I mean: as it was designed to be used - requires moving that fearful switch while the engine is running!!! That's what it was designed to do, and as long as you don't accidentally turn it to "Off" while the engine is running everything will be just fine.
On La Nostra I have a 950 cold cranking amp starting battery to turn over the big 82 HP Perkins. Once fired up I switch to "All". After I shut the engine down (either at the end of the day or when sailing) I switch to "2" and run off the four 6-volt Deep Cycle Golf Cart batteries - two in parallel, then in series to get the 12 volts for the system - and run everything from the approximately 600 Amp Hour house bank.
I've run things like this on all my boats. I typically get 4 or 5 years from a set of batteries. The ONLY time I start on "All" is if for some reason the starting battery won't kick the diesel over - which is extremely rare.
I should also add that I never plug in to shore power - we do not have it available anywhere I sail. Instead I use a KISS wind generator and two 80 watt solar panels and am able to run the fridge, freezer, water pumps, lights, radios, etc. for days on end without starting the engine.
Hope that puts people's minds at ease - and will also save some of you from spending big bucks on the wrong kind of batteries to do the various things on your boats.
Captain Harry
Life's Short ... Eat Dessert First!
La Nostra - CSY 44
Located Southern Caribbean
harryrezz is offline
post #50 of 67 Old 09-30-2008
moderate?
camaraderie's Avatar
Harry...lest someone think that ONLY a starting battery can or should be used to start an engine...let me just add that it is QUITE acceptable to use deep cycle batteries to start your engine. They will not deliver the same CCA's as a starting battery...but most marine diesels don't need extreme amperage and verycold weather starts and a decent sized house bank of deep cycle batteries does just fine in this role. Many people with limited ROOM for batteries would be better off configuring TWO deep cycle batteries with a 1/2/Both switch and starting with the switch on BOTH...thus giving more deep discharge amp hours available for house needs.
A 100ah group 31 battery will NOT for example power a fridge AND other house needs for a day since you can only discharge 50amphours safely.
If you use 2 deep cyclce 31 batteries to start and for house needs...you nnow have 100ah's to power house needs AND both batteries will still be at 12.25V when that has been used so you can still start the engine.
camaraderie is offline
READ THIS TODAY-It may save you an engine or at least some time and money! Marleetet Gear & Maintenance 6 07-14-2008 04:28 PM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
My New Catalina 25 42ndstreet General Discussion (sailing related) 23 09-06-2007 12:17 AM
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 07:00 PM
