Switching battery banks with engine running - Page 6 - SailNet Community
post #51 of 67 Old 10-01-2008
I'm recommending that you install a BlueSea Dual Circuit Plus Battery Switch and an ACR or a BlueSea Dual Circuit Plus Battery Switch and an echo charger. You do not need both an echo charger and a battery combiner.
Originally Posted by davidpm View Post
Are you saying an install could benefit from both? How.
They look similar in function.
sailingdog is offline
post #52 of 67 Old 10-01-2008
Maine Sail's Avatar
The easiest..
the easiest thing to do to prevent frying the diodes is this.
#1 Remove and move the charging wire that goes from the alternator to the battery switch. Move the switch end of this wire and wire it direct to the house bank. Now you can not disconnect the "load" from the alternator with the engine running as it's now wired direct to the load/batteries.
#2 Add an ACR type charging relay, automatically combines banks when it senses charging voltage, or an Echo type charger which is basically a 12V battery charger that kicks on at charging voltages to charge the start bank without actually combining them.
You have retained your 1/2/OFF/BOTH switch but made it safe for your alternator. Just remember that it will not eliminate "stupidity" and the human factor of you leaving your switch in the "both" position and killing both banks...
______
-Maine Sail / CS-36T
Maine Sail is offline
post #53 of 67 Old 10-01-2008
Halekai-
If you find something that can eliminate "Stupidity", I'll buy a case or two of it and spray it at people I have to work with to make my life easier...
post #54 of 67 Old 10-01-2008
sailortjk1's Avatar
Did anybody see my post?
I am still wondering what you guys think of this set up?
I like it. It seems to be a little easier to use. Its obviuosly not fool proof. I never had a boat with this type of switching before and I am curious as to why there are not more out there like this.
Or just ignore it......
Bump
Originally Posted by sailortjk1 View Post
Am I the only one who does not have a typical battery swich?
This subject comes up a lot and I was wondering if my system is any better or worse or what you guys think.
Our boat does not have a battery switch as it is commonly reffered to, we have (3) T-Handles mounted down in the aft berth. (1) for the Gound, (1) for Battery 1;starting, and (1) for Battery 2; House Bank. I have tried to find a photo but I don't have one and I can't find an example of the set up anywhere on line.
With the handle in the Vertical position the battery is off, and in the Horizontal position the Battery is on.
I always leave the House on and use that to start the engine, when I want to charge the starting batt I flip the lever to Horizontal. No problems and it seems a lot less confusing than the typical 1, 2, Both. I simply have to remember to NEVER switch off both batteries or to flip both the handles to the Vertical position when the engine is running.
Courtney is My Hero
sailortjk1 is offline
post #55 of 67 Old 10-01-2008
TJK-
Can you post a photo of said battery switch setup???
post #56 of 67 Old 10-01-2008
sailortjk1's Avatar
TJK-
Don't have one currently, I can try to get one this weekend.
Go White Sox!
Courtney is My Hero
post #57 of 67 Old 10-01-2008
Bump
My boat has the same set up, I like it also. It is easy to cut a battery in or out for charging or starting.
bubb2 is offline
post #58 of 67 Old 10-01-2008
sailortjk1's Avatar
Thanks Mike.
I knew I couldn't be the only one out there.
When are you leaving for St. Pete's?
Courtney is My Hero
post #59 of 67 Old 10-01-2008
Moderator
JohnRPollard's Avatar
Thanks Mike.
That's the typical French set-up. My sister's Bene 285 has it as well. She has two reds, and one black T-handle. I always thought the black was the combiner?
JohnRPollard is offline
post #60 of 67 Old 10-01-2008
No John, that black one is the electrical disconnect, the one you don't want to touch when the engine is running!!!!!
bubb2 is offline
READ THIS TODAY-It may save you an engine or at least some time and money! Marleetet Gear & Maintenance 6 07-14-2008 04:28 PM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
My New Catalina 25 42ndstreet General Discussion (sailing related) 23 09-06-2007 12:17 AM
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 07:00 PM
