Old 10-01-2008
JohnRPollard's Avatar
Moderator
Originally Posted by bubb2 View Post
No John, that black one is the electrical disconnect, the one you don't want to touch when the engine is running!!!!!
Uh oh!
Just kidding. I don't think they ever fiddle with them, but I'll be sure to remind them.
On their boat, they only have two batteries, and they are connected. In other words, either one can be selected and used as the starting battery, and they can be used singly or in combination as a house bank. That might be different from Tim's set-up?
Thanks Mike.
  #62
Old 10-01-2008
bubb2 has a spectacular aura about bubb2 has a spectacular aura about bubb2 has a spectacular aura about
John on my bennie, the batteries (2) are on separate on/off switches and the 3th switch is the master on/off. The battery switch and the master must be on in order for the battery to charge.
  #63
Old 10-01-2008
harryrezz's Avatar
Charter Captain
Location: Buffalo, NY (warm months), Liveaboard in Caribbean (cold months)
harryrezz is on a distinguished road
Camaraderie - I agree to a point .... that would certainly be better than two "starting" batteries ... but I'd suggest that the optimal setup where space is limited would be two "Dual Purpose" type batteries. That way there would be plenty of CCAs in either batery to start the engine, and nearly as many amp hours in reserve as one would have with a pair of "deep cycles" .... and I believe you'd get more longevity than with a pair of deep cycles which had been subjected to starting use. At least that's what the tech advisors told me at Decca Battery which is located near where I used to live.
I should have mentioned in my post that there is also confusion among many people about what constitutes "different types of battery" when it comes to combining them in one electrical system. This was mentioned briefly in this thread, but it bears underscoring.
It is fine to combine "starting", Dual purpose" and "deep cycle" batteries in one system as long as they are all of the same construction type. By this I mean they should all be "wet cell" types (the typical battery with lead plates suspended in an acid solution and which usually must be topped up with water) OR "AGM" batteries in which the acid is absorbed in glass mats between the plates OR "gel cell" batteries in which the electrolyte is in the form of a gel. The latter two are considerably more expensive to buy, but generally offer more usable power size-for-size, will not spill acid out if overturned (such as in a knockdown or capsize) and last longer with minimal maintenance. Wet cell, AGM and gel batteries should NOT be used in the same system because they have different charging parameters. Because they accept charges at different rates when they are in the same system the probability exists that one type will be under charged while the other will be over charged and ruined.
FWIW, I probably should also have mentioned that I personally am using a Balmar 100 amp alternator fed through a Balmar three-stage "smart regulator" and a battery combiner such as mentioned earlier.
Captain Harry
Life's Short ... Eat Dessert First!
La Nostra - CSY 44
Located Southern Caribbean
  #64
Old 10-01-2008
Moderator
Originally Posted by harryrezz View Post
Camaraderie - I agree to a point .... that would certainly be better than two "starting" batteries ... but I'd suggest that the optimal setup where space is limited would be two "Dual Purpose" type batteries....
Harryrezz,
I'm going to respectfully disagree with you on that point. On a sailboat lacking space for a dedicated starting battery, the better arrangement would be two deep cycles. They have no problem handling the starting loads, and are much better suited to handle domestic loads for long periods between charging.
If we were talking about a motorboat, like an express cruiser or sport fish, where abundant charging takes place any time the boat is underway, I'd agree with your suggestion.
  #65
Old 10-01-2008
camaraderie's Avatar
moderate?
Harry...a typical 100amp group31 deep cycle battery has 1/2 the CCA's as a starting battery. Thus TWO group 31 deep cycles can provide exactly the same CCA's as a group 31 start battery AND provide 200amp hours (100amp hours to 50%) of house bank needs. This is a MUCH better solution than a dual use battery which has thin plates and a short life in deep cycle applications.
BTW...I am assuming you have the same Perkins as I do..and I have the same Balmar setup...but my 8kw gen does my charging typically with a 135amp charger to 1000amphours of 8D AGM's. A very different situation than is being discussed here.
  #66
Old 10-01-2008
captbillc's Avatar
ancient mariner
captbillc is on a distinguished road
Wink battery & charging setup
small diesels like the yanmar 2GM20F in my 30 nimble express do not need the CC amps that larger diesels require. i have 4 golf cart 6v batteries in 2 banks with a rotary switch & a battery combiner. i have plenty of ampere hours for my needs with this system and do not have to worry about accidently turning the rotary switch off because the 2 combiner outputs are hooked to the 2 battery connections on the rotary switch.
  #67
Old 10-01-2008
Maine Sail's Avatar
Dual purpose no..
Did the tech bother to ask you how many cranking amps you engine actually required? Sure, if you have a 3208 Caterpiller you might need 700 cranking amps but with a small aux diesel you don't!
For example my 44HP 4 cylinder Westerbeke has a max rated cranking amp draw of 160 amps. In the real world, as measured by my Xantrex XBM, she's never pulled more than 100 amps to actually start my engine. Even the smallest personal water craft battery has more than 100 CCA!
People often over estimate the amount of load or amp use caused by engine starting. I can start my engine and not even measure 1 tenth of an amp hour used.
Standard deep cycle batteries will last longer and also will start any sailboat aux engine in the 30-50 foot range. Using start batteries or dual purpose batteries is 100% unnecessary with small aux engines unless you need to save money. I have not owned a start type battery in over 10+ years...
Here are two photos I took the first is prior to starting, after a night on the hook, the second is immediately following engine start. As you can see the amp hours required to start my 44hp diesel were not even measurable...
Before Start:
Immediately after start:
______
-Maine Sail / CS-36T
You may post attachments
You may edit your posts
READ THIS TODAY-It may save you an engine or at least some time and money! Marleetet Gear & Maintenance 6 07-14-2008 04:28 PM
Electrical Problem - Newbie Not Sure Where to Start wolfmt Gear & Maintenance 32 07-14-2008 09:17 AM
Installing a Automatic Battery Selector Switch artbyjody Gear & Maintenance 24 07-08-2008 07:07 PM
My New Catalina 25 42ndstreet General Discussion (sailing related) 23 09-06-2007 12:17 AM
A Little Help from the Sun Don Casey Cruising Articles 0 12-20-2001 07:00 PM
SEO by vBSEO 3.6.1
