Cleaning nasty greasy bilges? - Page 2 - SailNet Community
 1Likes
post #11 of 33 Old 09-28-2008
Dawn, a scrub brush, water, and a wet/dry shop vac are the tools you need.
SteveInMD is offline
post #12 of 33 Old 09-28-2008 Thread Starter
Zogumwesterly's Avatar
Thanks for the input. I'll try to work up the nerve to get goin on it soon
Zogumwesterly is offline
post #13 of 33 Old 09-29-2008
poopdeckpappy's Avatar
Find a product called Oil Eater, I used to get it at HD, it is absolutely the best. I have used this for years cleaning up the shop after breaking down the race bikes.
far better and enviromentally safer then purple power
Oil Eater Brand - Industrial & Household Cleaners, Absorbents, & Cleaning Equipment
1955 Blanchard 51 Custom ( I got a woody )
1974 Ranger 33
Friends don't let friends do stupid things alone
poopdeckpappy is offline
post #14 of 33 Old 09-29-2008
jarcher's Avatar
Originally Posted by merc2dogs View Post
... as it's will de-fat your skin.
Wouldn't many people see this as a benefit?
jarcher is offline
post #15 of 33 Old 09-29-2008
No, because it damages the skin and causes it to look much older and makes it less resilient. If it could de-fat the head, it would help a lot of people IMHO though...
sailingdog is offline
post #16 of 33 Old 10-06-2008
'Tide Regular Scent' - it works great!. I will first take care of the Oil - separately and dispose it safely. Then a spoonful of Tide in the bilges. Let the rocking of the boat shake things up and then wash it off with some water (the bilge pump should do the trick). I doubt if any of the cleaning fluids harm epoxy+glass, but they sure will harm the water where the boat stands. Tide is relatively safe and leaves the insides smelling good.
Good luck!
Venkat
pvenkat is offline
post #17 of 33 Old 10-06-2008
Bilge de-oiler
The most amazing product I've used is TKO, a brand of d-limonene, the chemical name for orange oil. It isn't cheap but nothing cuts oil better.
The fact that it is produced only from oranges makes it environmentally friendly. The same caution applies regarding skin contact, though. Gloves are mandatory if using it undiluted. Don't ask me how I know! I buy it by the gallon. And of course it smells great if you like oranges.
Lee Stone
s/v Aurora
flee is offline
post #18 of 33 Old 10-06-2008
Some of the purple cleaners are LYE based, be vrey careful about that. Even diluted, lye is caustic and may remove paint and varnish and soften or discolor fiberglass if it is not neutralized (dilute acid washed) when you are done with it.
A friend of mine got too enthusiastic, I believe with the original Castrol purple cleaner, and years ago took the varnish off his kitchen cabinets. "OOpsie."
Steam is great, but for some of us it is impossible to locate or rent a steam genny, you need to be in farm country to find them!
hellosailor is offline
post #19 of 33 Old 10-08-2008
TG29's Avatar
Sugar soap. The stuff you use for cleaning surfaces before house painting. Works a treat. I wouldn't pump the resulting slurry overboard, however.
I must go down to the sea again ...
TG29 is offline
post #20 of 33 Old 10-08-2008
That's where the wet/dry vac comes in. Vacuum up all the nasty stuff and flush it down a toilet (on land).
Cleaning NASTY canvas. CharlieCobra Gear & Maintenance 8 10-23-2007 07:15 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 07:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
