Cleaning nasty greasy bilges? - Page 4 - SailNet Community
 1Likes
post #31 of 33 Old 08-25-2009
Live to Sail
HatterasJack's Avatar
I have always found that Dawn dish soap workes well with a little elbow grease and hot water. Jack
HatterasJack is offline
post #32 of 33 Old 08-25-2009
bheintz's Avatar
Please do not pump any oily bilge water over the side:
All bilgewater discharges must be in compliance with the regulations in 40 CFR Parts 110 (Discharge of Oil), 116 (Designation of Hazardous Substances), and 117 (Determination of Reportable Quantities for Hazardous Substances) and 33 CFR 151.10 (Control of Oil Discharges).
In addition: National Pollutant Discharge Elimination System (NPDES) 2.2.2 Bilgewater - Vessel operators may not use dispersants, detergents, emulsifiers, chemicals or other substances to remove the appearance of a visible sheen in their bilgewater discharges.
Sure these regulations are mainly for larger vessels: over 65 ft / 400 gross tons, however the EPA is on the watch for "point source" violations. If it can be proven that the small boat operators are responsible, they will have the impetus to broaden the scope of the enforcement.
Originally Posted by SteveInMD View Post
Vacuum up all the nasty stuff and flush it down a toilet (on land).
Many (most?) municipalities are quite specific on what chemicals can not be dumped into the sewer. Such as, one location specifies "non-toxic and phosphate free cleaners and detergents. Furthermore, cleaners and detergents should not be caustic or only minimally caustic and should be biodegradable."
Basically oils, grease, and chemicals are not conducive to the sewage treatment process.
bheintz is offline
post #33 of 33 Old 08-25-2009
Oily bilge water can usually be dumped totally legally in the "waste oil" tank that most marinas and service stations keep for that purpose. The waste oil is then usually sold and refined.
Oilzorbs and other absorbent pads usually just go in the solid trash.
Getting bacteria to eat the stuff, so it is no longer oil, is a nice idea if it works.
hellosailor is offline
Cleaning NASTY canvas. CharlieCobra Gear & Maintenance 8 10-23-2007 07:15 PM
Spring Hull Cleaning Tom Wood Gear and Maintenance Articles 0 04-05-2004 08:00 PM
Sail Care and Cleaning Kathy Barron Gear and Maintenance Articles 0 10-20-2003 08:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Gear and Maintenance Articles 0 03-07-2002 07:00 PM
Cleaning Fiberglass Hulls and Decks Sue & Larry Her Sailnet Articles 0 03-07-2002 07:00 PM
