09-28-2008
Sea Slacker
Window sealant
I am sure this was discussed before, but I can't find the topic
It is time to rebed a couple of windows (can't call them portholes by design) - they are basically clear plastic (looks like acrylic to me) attached to the topsides with sealant and screws (not thru-bolts as I discovered to great relief today, otherwise I'd have to take apart the entire cabin to replace one window - what a disaster that would be  ).
Currently, courtesy of PO, they are installed with silicon and then sealed with some sort of polyurethane around the edge (yikes, that will be fun to remove, on the upside this does hold up pretty well).
What I am looking for is a single adhesive/sealant that works well for windows, providing both reasonable adhesion strength and sufficient flexibility to allow for heat expansion etc. Also, something that is easy to work with/clean up.
