09-29-2008
In my few years of repairing fiberglass, I have sanded and grinded my share of gelcoat. Other than impact damage, the one outstanding issue of cracks in gelcoat I believe are caused by an excessive thickness of the gelcoat applied to the mold. Of course your hull and deck will flex somewhat during it's life. The gelcoat does not like this movement, and does not flex the same as the glass and resin. As with everything in life, something is gonna give. The craftsman originally probably sprayed the gelcoat into the mold taking extra care around any hatches and any other areas with inside corners to lay on a good opaque coat. As the gelcoat is quite liquid it pools in some areas, resulting in a thicker coating with no flexibility. Go down to the yard and examine the cracking areas. I am sure that if you were to take a grinder and slowly grind through the gelcoat till you reach glass, and also do a small area that isn't cracking. You will most likely find an excessive thickness of gelcoat in the cracking areas. If the repair is simply grinding out old gelcoat and cracks, then re-applying new gelcoat in the same thickness, you will be tasting this bitter pill again.
