Old 09-29-2008
j34035's Avatar
"Sparkie"
j34035 is on a distinguished road
Hookah dive rigs
This past weekend I borrowed a friends BrownieDive 120 volt hookah dive rig to clean the bottom of the boat. It worked really well, and I would like to purchase one, but would like to have one that runs on 12 volts so I can use it away from the dock. Anyone have feedback on what the best unit is out there? Thanks for the help!!
DD
Doug
Jboat J/37c (new to me Jan 2011)
Old 09-29-2008
BluewaterBruce is on a distinguished road
Gas Powered engine drive?
Old 09-29-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
My friend made one up himself. Get a high pressure inflatable dinghy pump (4-7psi), connect a long flexible plastic conduit (used for wiring) to a snorkle, Tee-off near the snorkle top to another short length of conduit and end with a plastic throttling valve. With this throttling valve, you can adjust the bleed-off pressure slightly so that you won't be over pressure by the pump and yet can throttle in if you go deeper. Do not understand estimate water pressure at 4-8 feet below. The snorkle must have an over-pressure one-way valve. That's your safety device in event you shut the bleed-off too much and pump pressure is coming in. You won't want to puncture your lung. Any decent snorkle should have this feature.
This arrangement is good for cleaning even the keel. Depth is depandant on the pump pressure.
There is always an element of risk, its up to you to manage that.
7 feet of water is approx 3.0 psi
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 09-29-2008
davidpm's Avatar
davidpm is on a distinguished road
I wonder if there is any issue of lack of filtering of the air?
Old 09-29-2008
Air filter ?
Air filter/quality shouldn't be an issue. The pump is just a 12V pump from WM. If you put it in proper place then air quality is as what you breathe in. The pump would run hot after 10-20 mins. So that's the dive time. It should be enough to get alot cleaning done and have a break every 15mins.
Ken
Old 09-29-2008
poopdeckpappy's Avatar
poopdeckpappy has a spectacular aura about poopdeckpappy has a spectacular aura about
DD
Hookah direct drive scuba diving equipment sales. Hose diving hookah breathing regulators and gear. Hooka hose diving breathing systems, compressors, and gear.
This might work also
1978 Tayana 37
Freedom comes when you’re ready to sail away. True freedom comes when you don’t have to return
Cut off from the land that bore us, betrayed by the land we find, where the brightest have gone before us and the dullest remain behind, .......but stand to your glasses, steady,.......tis all we have left to prize, raise a cup to the dead already, hurrah for the next that dies
Old 09-30-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Also have a look at SeaBreath:
Sea Breathe, The Electric Snorkle
I use an electric hookah every day in my business but have never tried a 12-volt system. For my money they are definitely recreational-level gear and not robust or powerful enough for my needs but for the ocassional hull cleaning or fun dive it might work fine.
"Clean bottoms are FastBottoms"
Old 09-30-2008
If you're making one yourself, you really want an oil-less compressor design, as the very fine oil that gets suspended in the air of most air compressors is really bad for your lungs. You also want a regulator at the diver's end...
Old 09-30-2008
xort has a spectacular aura about xort has a spectacular aura about xort has a spectacular aura about
my research led me to believe 12 volt systems are the least effective of the three choices. They can't pump enough air to get you very deep and they use a lot of battery power. So if you are sure you don't need to go more than 10' to 15' and you either have a very big battery or a very short dive time then go for it. Otherwise, think 110 volt or gas.
Old 09-30-2008
j34035's Avatar
"Sparkie"
I dont need very deep dives on our lake as the visibility is really poor, but time enough to do a bottom clean is important to me. The 120 volt rig I used was great, but would really like to be able to use it away from the pier. Maybe driving a 120 volt rig with and inverter would be a solution?
DD
Doug
Ketch vs Sloop? bobmcd Boat Review and Purchase Forum 24 05-11-2010 03:35 AM
My First Boat...Boat Term Question... Kacper General Discussion (sailing related) 38 09-23-2008 06:52 PM
Ketch/Yawl Handling svsymphony Seamanship 19 07-05-2008 01:19 AM
Sloop or Ketch? maxheadspace Boat Review and Purchase Forum 46 07-27-2007 02:56 PM
Yawl Info Needed sailortonyb1 Boat Review and Purchase Forum 5 01-18-2006 04:51 AM
