09-30-2008
Hopefully, the wiring in the mast is secured in a conduit... if not, it really should be.
As for the turning block, it can be done either way. IIRC, Craigtoo modified his boat to have the blocks on the cabin top, where I used plates bolted to the mast step instead.
BTW, why do you need a winch for the mainsheet on a catalina 30???
