Old 09-30-2008
landlockvasailor's Avatar
landlockvasailor is on a distinguished road
Bench Testing DC 12 volt
I need to bench test equipment and my old power supply is toast. The one that I am looking at is a 13.8 VDC with 4 - 6 Amps. I cannot recall whether most 12 volt DC systems would be safe. Any thoughts?
When I go, let it be by boat, with a steady breeze on the Chesapeake with a bottle of 7-up, a bag of ice, a plastic cup, and a box of wine
Old 09-30-2008
Yes, that should be fine... Bulk charging current for most 12 VDC systems is 14.4 VDC or so.
Old 09-30-2008
Hartley18's Avatar
Termite Fodder
Hartley18 will become famous soon enough Hartley18 will become famous soon enough
Any reason you wouldn't use an old battery with an in-line fuse attached?
I've got a small motorbike battery on my bench for just that purpose..
Cameron
Crew member on the Womboat for:
2011 Heaven Can Wait 24Hr - Race against Cancer.
Old 10-01-2008
EO32's Avatar
EO32 is on a distinguished road
I use a car battery charger when working with 12 volt equipment. I figure most 12 vdc items can take a range of inputs, since your battery bank voltage varies when in use.
If a man must be obsessed by something, I suppose a boat is as good as anything, perhaps better than most. A small sailing craft is not only beautiful, it is seductive and full of strange promise and the hint of trouble.
- E.B. White
Old 10-01-2008
Hartley18's Avatar
Termite Fodder
I used to use a car battery charger - a nice 10A one too - until I blew up the regulator one day..
Unfortunately, battery chargers are not power supplies and are not designed to work very well (or very long) on high-resistance loads. If that's all you've got, I'd strongly suggest hooking an old battery up in parallel with the output... or suffer the consequences.
Cameron
Old 10-01-2008
LittleWingCA is on a distinguished road
An adjustable power supply that you can vary output voltage and set current limits is ideal since you can adjust the output voltage to simulate batteries that are getting weak. Adjustable current limits are nice too if you are testing equipment with different needs, and want to add some level of short protection, or ensure power ratings aren't exceeded.
LittleWingCA
1980 Pacific Seacraft Orion 27
Sailing Grounds: Southern California
Old 10-01-2008
Thanks for all the information, it is appreciated
6 Volt Battery Sailpilot Gear & Maintenance 19 03-18-2008 07:30 PM
6 volt golf cart batteries hollyp Gear & Maintenance 6 12-02-2007 05:38 PM
Hilarious Pract. Sailor Article testing waterline stain removers labatt Gear & Maintenance 17 11-03-2007 10:06 PM
12 volt to 24 volt conversion SMIK12 Gear & Maintenance 1 04-18-2005 01:50 PM
6 Volt Batteries vs 12 Volt ABullard Gear & Maintenance 10 09-06-2001 05:41 PM
