Old 10-01-2008
NOLAsailing's Avatar
NOLAsailing is on a distinguished road
I agree with both you guys. But I assumed the OP was saying he had this problem when he's not sailing, i.e. when the main is flaked and he snugs the sheet to keep the boom from swinging back and forth? Maybe not...
The halyard run back and clipped to the outhaul or a ring at the end of the boom and tentioned should prevent this. The halyard should be run back anyway as a courtesy to others in the marina.
-Jason
  #12
Old 10-01-2008
craigtoo's Avatar
Barkeep - Sailor's Pub
craigtoo will become famous soon enough craigtoo will become famous soon enough
Send a message via AIM to craigtoo Send a message via Yahoo to craigtoo Send a message via Skype™ to craigtoo
*clang* *clang* *clang* *clang*
-C2
1987 Sabre 34 "Saoirse"
Meet me at the
I love
  #13
Old 10-01-2008
craigtoo's Avatar
Originally Posted by JohnRPollard View Post
Even if I had a boom kicker, I'd still want the topping lift. If you're seriously into racing and don't want the topping lift flailing around while sailing, you can design it to be quick release at the boom end and bring it forward to the mast when sailing...
Hey JRP,
What would you use the Toppinglift for if you had a boomkicker?
I've tied mine off to the mast and never use it except for MOB.
-C2
Meet me at the
I love
  #14
Old 10-01-2008
JohnRPollard's Avatar
Moderator
Originally Posted by craigtoo View Post
Hey JRP,
MOB recovery is one good reason. Most booms aren't made to support weight out at their ends while being jacked up only at the vang attachment point. I've seen more than a few that creased where a solid vang was attached. Not necessarily from MOB recovery (could have been a crew that climbed out to grab a line, or a few kids just laying across the top of the boom at anchor -- like mine do). A flexible boomkicker probably wouldn't crease the boom, but it might collapse.
Also, we have Dutchman lazyjacks that rig down from the topping lift.
  #15
Old 10-01-2008
craigtoo's Avatar
Good stuff thanks John...
-C2
Meet me at the
I love
  #16
Old 12-22-2008
captainmidnight is on a distinguished road
THAT IS MONEY(as in he's correct!)
  #17
Old 12-23-2008
I just can't fathom the need for a topping AND a rigid vang/boom kicker. Can someone please explain that???
OP: just attach the main halyard to the boom end when you're at the dock and harden it up to keep the boom from striking the dodger or excessively swinging. Fast, simple - FREE.
-Jason
  #18
Old 12-23-2008
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
Originally Posted by ralphmacey View Post
There is a rigid vang now, but when I sheet in the main the boom hits the top of the dodger.
Something isn't right, then. Either you're not hauling the main up all the way, it's blown-out or the dodger is too high.
Can the rigid vang be adjusted to prevent that from happening?
I don't know, for sure, but, if it could, it would have the same effect as using a topping lift to accomplish the same end: A floppy, misshapen, poorly-performing main. Except perhaps...
Don't quote me on this, but I believe there are conditions under which a topping lift is used to adjust the shape of the mainsail, in conjunction with vang sheeting. (This would be a performance racing technique.) I don't know if the same can be done with a rigid vang.
Jim
  #19
Old 12-23-2008
blt2ski's Avatar
While I realize this thread is older, If the boom "IS" hitting the dodger, to me, the clew needs to be raised by cutting a small triangle out of the foot. OR, redo the dodger.
marty
She drives me boat,
I drives me dinghy!
  #20
Old 12-24-2008
Or the main isn't being hoisted completely... or the leech has blown out on an older sail and it needs to be replaced....
marty
You may post attachments
You may edit your posts
Topping Lift sehopkins Learning to Sail 10 03-31-2013 10:26 PM
routing outhaul and topping lift terryjoe Sailboat Design and Construction 15 07-27-2008 01:19 AM
Topping lift vs. boom kicker tcase10 Gear & Maintenance 23 06-14-2008 11:18 AM
Topping lift denby General Discussion (sailing related) 82 05-16-2008 09:18 AM
Topping lift PBzeer Seamanship 11 02-19-2004 07:39 PM
SEO by vBSEO 3.6.1
