Old 10-01-2008
mikehoyt's Avatar
mikehoyt is on a distinguished road
ST60 wind initialize?
Inherited a used ST60 wind system. When testing not on boat would not display wind speed. Direction indicator on display slowly turns counter clockwise continuously.
Wondering if there is a calibration that is required or if this instrument is toast. If it works fine - otherwise not cutting a hole in bulkhead for installation and no plans at this time to replace with a new one.
Anyone else experiencethis symptom?
Mike
Old 10-01-2008
Have you checked the wiring to the transducer??
Old 10-01-2008
jimmalkin's Avatar
jimmalkin is on a distinguished road
check the wiring as SD says. There is a calibration that involves making 2 360 degree circles but I don't recall. If you can't find the instructions on the Raymarine website - which takes a bit of time, but is do-able - pm me and I'll look it up in my manual. I'd need to know whether this the two display wind and closehauled system or a single display and if so - what is the display named. Good luck.
White Rabbit
Vineyard Haven
Old 10-02-2008
mikehoyt's Avatar
Instruments are raytheon and Raymarine so that should give you an idea of when these three were purchased originally. The wind is Raytheon ST60 Wind. I cut the cable within a foot of transducer and respliced thinking the cable had been damaged removing from old mast - no change.
I tried walking in two (actually more than two) 30 foot dia circles with instrument powered up and transducer in my hand. no change.
Checked voltages to wires at transducer end using DC voltmeter. Not much there...
Mike
Old 10-02-2008
trantor12020's Avatar
trantor12020 is on a distinguished road
Was told that spinning the arrow twice slowly (like turning boat 2 circle) would initialize it. Give it a try. No need to take a walk.
Ken
2002 Hunter 326, SV Millennium 2
1999 Macgregor 26X, SV Millennium
Old 10-02-2008
Mike-
It could also be a problem with corrosion on the plug where the transducer attaches to the mast mounting base.
Mike
Wind Orientation Mark Matthews Learning to Sail Articles 0 03-06-2005 07:00 PM
Charging with Wind Power Kevin Jeffrey Cruising Articles 0 04-21-2003 08:00 PM
Understanding Apparent Wind Steve Colgate Learning to Sail Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Seamanship Articles 0 11-10-2002 07:00 PM
Understanding Apparent Wind Steve Colgate Racing Articles 0 11-10-2002 07:00 PM
