Old 10-01-2008
Leland is on a distinguished road
Looking for a new compass
my compass is old, has no light which would have really been nice the other night...and nothing to tell me the degree of heeling I am at. I am looking for a new one that has a light, tells me how far I am heeling and is AWESOME. give me some sugggestions....It needs to be bulkhead mounted for my oday 23
I am looking for any crew openings in California. Please Pm
Old 10-01-2008
I'd recommend the Plastimo 101 Compass. It looks like:
Available here at sailnet...click on photo to go to it.
The other advantage the Plastimo has is that it can be read from inside the cabin as well as outside in the cockpit... if it is installed next to the nav station, that can be handy.
Old 10-02-2008
Valiente's Avatar
Yes, that Plastimo is great. Just don't lose the grey plastic faceplate cover, as sunlight will yellow the oil. Also, unless you know what you are doing, having it professionally swung is a good idea, even with a little compass (I assume it can be swung, I don't know, as it was right when I bought the boat!)
The only other comparable compass at the low end is Suunto, I think.
Suunto - Home - SUUNTO B-95 SAIL - Marine Compasses
Old 10-02-2008
Danforth makes one as well, but I think the Plastimo is far easier to read.
Old 10-02-2008
how does that work? do you have to cut a huge hole in the bulkhead?
Old 10-02-2008
With all of the bulkhead mounted compasses, you have to cut a pretty big hole in the bulkhead. Huge is a relative term though... most of them require a hole about 3.5-4" in diameter. I like the Plastimo because it at least makes the most of the hole IMHO, since you can see the compass card from both sides.
They do make a smaller version of the Plastimo, which is located here. However, I wouldn't recommend it, since it doesn't allow you to swing the compass, since it doesn't have adjusters for the deviation IIRC.
Old 10-02-2008
catamount's Avatar
catamount is on a distinguished road
I really like the Suunto B-116 bulkhead compass
one possible source: http://www.apsltd.com/Tree/d321000/e318618.asp
Peterson 34 GREYHAWK, West Boothbay Harbor, Maine
, a new voice for ocean conservation
Old 10-02-2008
SEMIJim's Avatar
Last Grumpy Old Sailor
SEMIJim will become famous soon enough SEMIJim will become famous soon enough
We went with the Ritchie Navigation SR-2 Venture:
for the following reasons: 1. We liked the white lettering on a blue card. It seemed very readable. 2. Ritchie was most-highly-recommended by the compass repair guy I talked to down in Florida. 3. It was in-stock at a local marine supply store (and I like to buy local).
How readable is it? Well, ours is mast-mounted and we've a 30' boat. So that compass is about, oh... 10' from where The Admiral sits at the tiller and I at the winches, and we can both read it pretty well--at least during the daytime. (There's no power up there yet and we haven't sailed at night, yet, in any event, so I couldn't say about nighttime.)
Jim
s/v Abracadabra
1976 Pearson P30
Old 10-02-2008
bobmcgov's Avatar
baDumbumbum
bobmcgov will become famous soon enough
An excellent low-cost choice is Rule's Saturn, available in flat or front-read. Only $82, really large, seems well-built. Integral clinometer. My only complaint is on the front-read, with our slightly angled bulkhead, a gimbal can obscure the gradations slightly. Depends where you are sitting.
Buccaneer18, Grainnia
SJ21, Diarmuid
Old 10-02-2008
lharmon is on a distinguished road
This option doesn't require cutting any holes and is readable from below. All you need to do is detach it from the included adhesive mounting strip. It is also removable when you are away from the boat so theft is no longer a worry. The product is shown with the optional inclinometer.
It's better to have your enemies inside your tent pissing out than outside your tent pissing in...
Understanding and Using the Magnetic Compass Jim Sexton Learning to Sail Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Seamanship Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Gear and Maintenance Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Cruising Articles 0 03-01-2000 07:00 PM
Understanding and Using the Magnetic Compass Jim Sexton Her Sailnet Articles 0 03-01-2000 07:00 PM
