Old 10-02-2008
davidih is on a distinguished road
wanted - paddle wheel for SL45
I NEED URGENTLY a new paddle wheel for an SL45 and Std Horizon don't supply them anymore according to the Australian (Perth) agent I used. Can anyone advise where I might get one please.
Old 10-02-2008
jldooley is on a distinguished road
I may have one. sent you a pm
Old 10-02-2008
welshwind's Avatar
Re-Member
welshwind is on a distinguished road
Try this link:
www.sailtechmarine.com/itemdesc.asp?ic=33-113
S/V Benediction
Beneteau 36CC
"To reach the port of heaven, we must sail sometimes with the wind and sometimes against it - but we must sail, and not drift, nor lie at anchor.”
- Oliver Wendel Holmes
Old 10-03-2008
Hi - many thanks to Westwind for reponding. I am not eligable yet to send you a PM so no photo ! The wheel has 8 quite flat blades (looks like a classic waterwheel !) is 26 mm - one inch - from tip to tip of blades across the centrepoint, two of the blades have (had) small magnets set into the tips. The wheel is 18mm or 3/4 inch wide. The spindle is about 2mm diameter.
Much appreciate this.
Old 10-03-2008
David-
Be aware that most of the transducers, at least in the United States are made by AIRMAR, and that the part that WELSHWIND pointed out will work in many models, even though it may not look the same as the OEM part. It says in the ad copy that it works in a Standard SL45 transducer, and is probably worth trying for the $20.
Old 10-07-2008
Many thanks to all who responded - what a great forum this is !!! I have found that the Navman paddle wheels are compatible with the Standard Communications SL45 speed log. Hope this helps others out there who can't get parts for their SC SL45 and thanks again to those who offered assistance.
Wanted - Sailboat Use Share NewsReader Mass Bay Sailors 0 10-15-2006 11:15 AM
Crew wanted for Tortola/Antigua...Caribbean cjay herSailNet 1 06-22-2006 06:48 PM
Crew wanted for Tortola/Antigua...Caribbean cjay Learning to Sail 1 06-11-2006 10:25 PM
Crew wanted for Tortola/Antigua...Caribbean cjay Chartering 0 04-18-2006 07:07 PM
What Does C.V. stand for in The Crew Wanted Ads montkap General Discussion (sailing related) 1 02-24-2006 12:59 PM
