Blogs
User Name
Old 10-02-2008
PeggySus PeggySus is offline
PeggySus is on a distinguished road
Changing Engine mounts on Bayfield 32- help!
The front engine mounts need replaceing on my Yanmar 2 banger. Problem. When one removes the hold down bolts one finds that there is a nut on the other side. A llose nut, in an inaccesable (I think) space between liner and hull. Has anybody experience of this? And what is the opinion about substituting Helicoils instead?
A really poor design. How did the engine get mounted in the first place, I wonder.
Any help much appreciated.
PeggySus
Old 10-02-2008
SteveInMD SteveInMD is offline
SteveInMD is on a distinguished road
While I'm not familiar with your boat, I found it much easier to unbolt the bracket that attaches to the motor from the motor first. Then remove the mount and bracket from the boat as an assembly. Then separate the mount and bracket on a workbench.
Old 10-03-2008
Rockter Rockter is offline
Rockter will become famous soon enough
This one needs a picture, methinks.
Sponsored Ad
Old 10-03-2008
billangiep's Avatar
billangiep billangiep is offline
billangiep is on a distinguished road
If you look under the engine there are four 1 1/2 hole's in the location of each mount. In some cases the fuel and bilge hoses are run through these and must be removed to access the nuts.
You start sailing with a bag full of luck and an empty bag of experience. The idea is to fill the bag of experience before you empty the bag of luck.
Old 10-03-2008
Re:Changing Engine mounts on Bayfield 32- help!
Steve,
Thanks for the response. Removing the mount is not a problem. It's access to the nuts that is. My mechanic, who noted the problem, may have come up with the best solution. I'll see this weekend.
Cheers.
Old 10-03-2008
Thanks for your response. I don't recall seeing said holes but I will check this weekend. My head tells me that they don't exist but then I've never looked for them. My mechanic, who noted the problem, may have come up with the best solution which is, funnily enough, to add a couple of 7/8 holes in the vertical surface of the engine bed on the forward end. Structurally I don't think this will be a bad thing. The alternative is to remove the cabin sole. Messy, but negates drilling.
Cheers.
Display Modes
vB code is On
Runaway Diesel Engine Ben Hilke Gear and Maintenance Articles 0 07-19-2004 09:00 PM
Caring for the Cruising Outboard Doreen Gounard Gear and Maintenance Articles 0 04-22-2003 09:00 PM
Surveying a Diesel Engine Tom Wood Buying a Boat Articles 0 01-26-2003 08:00 PM
Surveying a Diesel Engine Tom Wood Gear and Maintenance Articles 0 01-26-2003 08:00 PM
Replacing the Diesel Engine Sue & Larry Gear and Maintenance Articles 0 06-12-2000 09:00 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.0.0 RC8
(c) Sailnet 2000-2006
