10-04-2008
the pointy end is the bow
Another mis-truth that is often perpetrated amongst sailors is the absolute need for a "starting" type battery to start your small diesel engine.
Start batteries don't, and won't, generally last as long as a true deep cycle battery so pound for pound deep cycles generally cost less in the long run.
While I don't believe that starting batteries are absolutely required, I also don't think they're a bad idea. If deep cycle batteries were a good choice for starting engines, they would be in all our cars.
From what I've read, a starting type battery has a lower self discharge rate than the heavy duty wet cell deep cycle batteries. Starting batteries are also cheaper than deep cycle batteries and in my experience, starting batteries last a long time, when not deeply discharged. So, if you have a two bank setup and just run off your house bank all the time for engine starts and everything, you may find that your emergency bank is dead if you went with a deep cycle battery instead of a starting battery because of self discharge. That kind of defeats the whole purpose.
I doubt there is one best setup for all boats and their conditions. Just like everything else, there are compromises. Just as the standard 1-2-both battery switch works perfectly fine, you can spend all sorts of additional money to protect your system from yourself. you could also sail with a woman who always asks "did you switch the battery switch back over?" but I'm not sure that saves any money. Our boat has two banks, each with their own alternator.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
