Old 10-04-2008
jonb is on a distinguished road
Feathering Propellor - need help
We hauled out C&C 44 for the first time this past weekend. This boat was new for us in the spring.
After haulout we found that a ring at the front of the feathering prop has unscrewed itself and was laying loosing around the shaft.
I am not sure what kind of prop it is. It is a 3 bladed feathering prop. I thought it was a Maxprop but when I look at the on-line information and assembly manual my prop is completely different in design. Did Maxprop change their design?
I would expect that my prop is from the 1986 - 1990 period.
The 3 parts of the prop are all intact but loose because the ring holding them together has unscrewed itself. It appears as though there there should be a bolt that screws in to the front of ring that holds the ring in place and prevents it form loosening itself. Claerly this bolt fell out first and then the ring unscrewed itself and came apart.
The same assembly is intact on the back of the prop.
I have managed to start threading the ring back onto the assembly but it appears that a tool is needed to get it on further. There is a hole in the outside of the ring. Clearly a tool must wrap around the ring and a screw would be inserted into the hole in the ring.
Anyone who has information that could help identify the kind of prop that I have and where I would get access to the tool that is required to reassemble the prop would be appreciated.
C&C 44
Kingston/Lake Ontario
  #2
Old 10-04-2008
JonB-
A photo of said prop would make identifying it a lot easier. Also, it would help in identifying what tool is needed to tighten the ring.
  #3
Old 10-04-2008
erps's Avatar
the pointy end is the bow
That describes a spanner wrench. I have a Maxi prop from that time period, I'll see if I can find a picture of it.
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #4
Old 10-04-2008
I am trying to figure out how to post 2 JPEG images of about 90kB each.
For some reason I get an upload failure on both.
C&C 44
  #5
Old 10-04-2008
erps's Avatar
Ray
S.V. Nikko
1983 Fraser 41
La Conner, WA
  #6
Old 10-04-2008
No thats not it. My prop is quite different. If I can figure out how to upload pictures I'll post the two pictures.
C&C 44
  #7
Old 10-04-2008
Here are the pictures.
C&C 44
  #8
Old 10-05-2008
ASA and PSIA Instructor
Originally Posted by erps View Post
If you put a couple of coats of this petit Zinc Coat stuff PYI Inc. Max-Prop PSS Shaft Seal Seaview Radar Mounts R&D on your Maxi, you won't get any more of those barnicles.
  #9
Old 10-05-2008
SkywalkerII is on a distinguished road
If I'm not mistaken, you have a Variprop feathering prop. The giveaway is the zinc cone. I had one on my Tartan a few years ago. Check out their website.
Skywalker
  #10
Old 10-05-2008
Fstbttms's Avatar
I don't discuss my member
Fstbttms is on a distinguished road
Looks like it might be an old Autostream.
"Clean bottoms are FastBottoms"
You may post attachments
You may edit your posts
Origin of the Feathering Propeller tdw Gear & Maintenance 1 04-15-2008 07:37 PM
Folding vs. Feathering Prop? MJKahn Hunter 4 08-06-2007 09:54 AM
Propeller performance change - feathering paulmcquillan Gear & Maintenance 2 10-20-2003 07:48 PM
Choosing the Right Propeller Sue & Larry Gear and Maintenance Articles 0 02-04-2003 07:00 PM
Feathering Prop for Outboard Quickstep192 General Discussion (sailing related) 1 10-26-2002 06:52 AM
SEO by vBSEO 3.6.1
